Oil feed and return lines question?
Old May 3, 2005 | 04:42 PM
Bimmerman's Avatar
Default Oil feed and return lines question?
So I will be installing a t3/t4 on my car, what do I need for oil return and feed lines and hook ups to motor? can someone post a link to buy?
Old May 3, 2005 | 05:32 PM
oxSLEEPERxo's Avatar
Default Re: Oil feed and return lines question? (Bimmerman)
http://www.tunertoys.com
Old May 4, 2005 | 08:34 AM
RyanEJ8's Avatar
http://www.fast-turbo.com
or contact Stan (Flamenco-T on this board)
Old May 4, 2005 | 09:08 AM
Flamenco-T's Avatar
Here are the complete oil line kits for your turbo application,
The oil feed line kit,
The oil return line kit,
You do need to have a threaded oil drain flange for the oil return kit, most turbos comes with it, if not, I can supply you with an aluminum billet flange and gasket.
Pricing:
Oil feed line kit is $ 45
Oil return line kit is $ 75
Drain flange with gasket $ 18
Total $ 138 plus shipping, but I will give you a deal of all 3 kits for $ 109 shipped to your door.
We do accept credit cards (Visa, MC or Amex), paypal, check or MO.
paypal@fast-turbo.com
Please let me know if you have any other questions...
Stan
Old May 4, 2005 | 10:52 AM
Bulldogg83's Avatar
Fast-Turbo.com
Old May 4, 2005 | 11:16 AM
FOrSfEd's Avatar
Default Re: Oil feed and return lines question? (Bulldogg83)
Stan http://www.fast-turbo.com all the way
Old May 4, 2005 | 11:25 AM
Evanmb44's Avatar
definately go with fast-turbo. stan is a great guy with excellent service
Old May 4, 2005 | 04:25 PM
Bimmerman's Avatar
Default Re: Oil feed and return lines question? (oxSLEEPERxo)
where does they supply line hook to on the engine? and what is the best way and best place on the oil pan to put the hole?
Old May 4, 2005 | 05:08 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bimmerman &raquo;</TD></TR><TR><TD CLASS="quote">where does they supply line hook to on the engine? and what is the best way and best place on the oil pan to put the hole?</TD></TR></TABLE>
T fitting off of where the stock oil pressure sensor is.
Get an AN bulkhead fitting and weld it to the oil pan, just make sure its not obstructed on the other side.
Old May 4, 2005 | 05:19 PM
Sohc Driver's Avatar
Default Re: Oil feed and return lines question? (1 cam)
pics of my oil return line from Stan @ Fast-Turbo!
Old May 4, 2005 | 05:49 PM
eddyboy's Avatar
Default Re: Oil feed and return lines question? (Sohc Driver)
I agree Stan is the man. I got my oil line setup from him is well.
If you don't want to tee off the oil sender, I recommend a sandwhich adapter. Does clean up things quite a bit. But if you do tap off the oil sender Please run to a distribution block on firewall. I've seen to many fittings come loose or snap off in the block.
Here is my sandwich adapter
Old May 4, 2005 | 07:11 PM
.dave's Avatar
i HAS questions ?
Default Re: Oil feed and return lines question? (eddyboy)
I'll get pictures of mine this weekend. Fast-turbo kit mounted on the firewall.
Old May 5, 2005 | 05:27 PM
ilovemyeg2's Avatar
i am doing some research on oil lines, but i have never heard of a distribution block.... do you have a pic of this or can u give me a site that has one
thanks
Old May 5, 2005 | 05:46 PM
eddyboy's Avatar
Default Re: Oil feed and return lines question? (ilovemyeg2)
not so much as a distribution block but run a -3an line to your fittings which are mounted to the firewall. So the Oil sender on the block doesn't have to bear the weight of all the fittings and sensors.
check out this thread
https://honda-tech.com/zerothread?id=861318
TunerShark
Jun 30, 2007 09:31 PM
AzntaggeR
Oct 5, 2004 11:08 AM
Ad4mGSR
Jun 4, 2004 12:32 AM
civicshowracing65
May 15, 2004 08:27 AM
808b18c1boosted
Feb 15, 2004 12:00 PM
