Oil Return Question???
Old Apr 20, 2005 | 08:25 AM
gsrboost's Avatar
Default Oil Return Question???
How well do these bolt on oil return flanges compare to actually welding the fitting into your pan? Any one have experience with them?
Old Apr 20, 2005 | 08:27 AM
fastcivicboy's Avatar
That fitting is intended to go on your turbo drain not the oil pan, just to clear this up for you.
Old Apr 20, 2005 | 08:30 AM
EJ1 wilcox's Avatar
Default Re: (fastcivicboy)
No, they have bolt on oil return flanges that bolt onto the pan...
I have never used one, but I have friends that have them and don't have problems with them...
Just make sure you seal that sucker! You don't want it leaking...
*edit*
I hadn't seen the picture... the flange in the picture looks to be the flange that bolts to the turbo, not the pan.
Old Apr 20, 2005 | 08:34 AM
gsrboost's Avatar
Default Re: (EJ1 wilcox)
Can someone point me in the right direction to the one that bolts to the oil pan? I thought that was it, but i guess im wrong.
Old Apr 20, 2005 | 08:37 AM
nonvtecD's Avatar
Nothing bolts to the pan, you drill a hole, thread in the fitting and then weld it in.
Old Apr 20, 2005 | 08:41 AM
gsrboost's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Nothing bolts to the pan, you drill a hole, thread in the fitting and then weld it in.</TD></TR></TABLE>
No they have bolt on ones.[
Old Apr 20, 2005 | 10:08 AM
StockBlockRob's Avatar
Default Re: (gsrsp33d)
been using a "bolt on" one for about 6000 miles. not the same style but no leaks just have to do it right. but welding would be a sure way of it not leaking
Old Apr 20, 2005 | 10:29 AM
stealthmode62's Avatar
Default Re: (vtecrob16a)
You can use the drain flanges that were designed for the oil outlet. It's still three holes and hopefully a gasket. Wether you put it on the turbo or the oil pan, it does the same thing.
Old Apr 20, 2005 | 05:29 PM
gsrboost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecrob16a &raquo;</TD></TR><TR><TD CLASS="quote">been using a "bolt on" one for about 6000 miles. not the same style but no leaks just have to do it right. but welding would be a sure way of it not leaking</TD></TR></TABLE>
Yah i would rather weld it myself too but i dont have access to a welder so i figured i could just bolt one in as long as i hear good reviews about them.
Old Apr 20, 2005 | 05:30 PM
gsrboost's Avatar
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> You can use the drain flanges that were designed for the oil outlet. It's still three holes and hopefully a gasket. Wether you put it on the turbo or the oil pan, it does the same thing. </TD></TR></TABLE>
Thanks for clearing that up.
myessay
Feb 10, 2012 04:22 PM
cibao2ner
Jul 27, 2011 03:48 PM
civicsaremean
Apr 4, 2008 03:33 PM
oprac
10
Aug 8, 2007 08:05 PM
EikoU
Jun 12, 2006 08:14 PM
