Oil Return placement, right or wrong spot?
Old Nov 20, 2002 | 05:20 AM
rbf351's Avatar
Default Oil Return placement, right or wrong spot?
i'm getting my oil pan welded tonight and want to make sure it's in the correct place. i made a circle where i want it welded
[Modified by rbf351, 9:50 AM 11/20/2002]
Old Nov 20, 2002 | 05:26 AM
TurboCRVTEC's Avatar
Default Re: Oil Return placement, right or wrong spot? (rbf351)
that'll work fine
Old Nov 20, 2002 | 05:45 AM
PM-Performance's Avatar
Default Re: Oil Return placement, right or wrong spot? (TurboCRVTEC)
can you make the circle more visible, i cant see it .
Old Nov 20, 2002 | 05:46 AM
Cwest EK's Avatar
Default Re: Oil Return placement, right or wrong spot? (itr206)
looks good to me
Old Nov 20, 2002 | 05:51 AM
rbf351's Avatar
Default Re: Oil Return placement, right or wrong spot? (Cwest EK)
updated pic
Old Nov 20, 2002 | 06:52 AM
Old Nov 20, 2002 | 07:32 AM
RAWB's Avatar
Old Nov 20, 2002 | 09:04 AM
glagola1's Avatar
Default Re: Oil Return placement, right or wrong spot? (integracon)
It looks fine from here but you really need to consider where the turbo places the drain tubes. You want gravity to work with the draining effect. Try to place the drain so that the drain tubes go as vertical as possible. You could move the hole over to the left so more and it would be OK.
It's nice that these motors have a baffle on the block as opposed to the pan like on D-series.
Old Nov 20, 2002 | 09:10 AM
RGAZ's Avatar
New User
Default Re: Oil Return placement, right or wrong spot? (glagola1)
Yeah that D-series baffle is a pain to deal with. I ended up going underneath it with my tap.
As long as you don't have a flat run of more than a few cm's you wil be OK.
Randy
Old Nov 20, 2002 | 09:20 AM
rbf351's Avatar
Default Re: Oil Return placement, right or wrong spot? (RGAZ)
here is the inside of the pan
the turbo isn't going on till saturday and i'm having this welded so it's ready for saturday, so i really can't do a test fitment
Old Nov 20, 2002 | 10:38 AM
b18b98's Avatar
thats where i have mine tapped.
Old Nov 20, 2002 | 10:52 AM
FredoSP's Avatar
Here you go, from my Install
Old Nov 20, 2002 | 11:26 AM
rbf351's Avatar
Default Re: Oil Return placement, right or wrong spot? (FredoSP)
my tube is straight and not angled like that
it's from the revhard kit
so it just sticks straight out
the.hamburglar
Jul 16, 2005 08:34 AM
yusoslo
Mar 21, 2004 09:24 PM
KamikazeSol
Oct 6, 2003 02:19 PM
Steve91
May 29, 2003 08:43 AM
rbf351
Nov 7, 2002 11:26 AM
