oil return line 5/8 ID
I got the hose fitting on my turbo and was told to use high pressure/high temp. fuel line and connect in to the welded pipe in my pan. Ive called NAPA, CARQUEST, Advanced AUto, and even a few hydrolic hose places. No-one has 5/8 ID high temp fuel or diesel line. Any ideas. Everything else is done with the turbo setup.......just need the piece of hose. thanks
Re: oil return line 5/8 ID (Maveric)
I think i used heater hose before I used SS... if the line is reinforced (you can see strains of like string when you cut it) then it is rated for what you need.
found some from another forum - only problem now is that the temp range only goes up to 212 F . since the line has to be run between my block and downpipe, thats gonna be too hot. any ideas on what kind of material to wrap with and protect from heat
C1V1CS1
10-16-2002 12:23 PM
pelotudo
08-24-2002 12:20 AM
