oil return line..HELP!!!!! (pics attached)
Old Jul 3, 2007 | 08:26 AM
nicotine's Avatar
Default oil return line..HELP!!!!! (pics attached)
ok, so here's my problem
the guy who did my turbo install last year, didnt do it right. it fried my turbo off (dont care), and this year i did a new del sol up, eagle rods/je pistons/rings/valves/etc etc...
right now, running 8lbs of boost.
im not driving the car right now, cuz i know the car isnt right at all.... i know this return line is wrong and i dont wanna fry my garrett gt35r....
so, any suggestions appreciated on what to do about this oil return. please, no smart *** comments. i didnt do this work, but im smart enuff now to know it's wrong before i do any damage.
Old Jul 3, 2007 | 10:28 AM
esedulerp5tenin's Avatar
Default Re: oil return line..HELP!!!!! (nicotine)
it really doesn't look that bad at all. as long as the return line isn't going UPWARDS, since its a gravity feed.
you MIGHT be able to change the blue fitting on the oil pan to a 45 degree fitting, which i think would make the entire line flow down, instead of leveling out at the end
Old Jul 3, 2007 | 10:32 AM
stealthmode62's Avatar
Default Re: oil return line..HELP!!!!! (esedulerp5tenin)
Your pictures are a tad big, and a tad blurry. The only thing I could possibly pick out was a possible kink in the top picture?
Old Jul 3, 2007 | 11:11 AM
Mr HYDE's Avatar
shorten the line and get a fire sleeve for it
Old Jul 3, 2007 | 11:31 AM
nicotine's Avatar
how do i shorten the line???? never done it before...
i can get the 45 degree fittings....
also, what is a fire sleeve? is it like the heat wrap they do on the down pipes?
Old Jul 3, 2007 | 02:19 PM
thepariah25's Avatar
Default Re: (nicotine)
my oil return line is a reinforced vinyl/braided line from freakin home depot.......which is halfway kinked in half, i put a hose clamp on the minor kink and opened it, its clear so i can see the oil flow, but its SCARY!!!
WOOOooooWWOoooOOoooo
Old Jul 3, 2007 | 02:41 PM
IN VTEC's Avatar
I vote for 5/8" hard line with -10AN tube sleeves and nuts.
Old Jul 3, 2007 | 04:13 PM
EG civic's Avatar
Default Re: oil return line..HELP!!!!! (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">shorten the line and get a fire sleeve for it</TD></TR></TABLE>
I agree shorted the line and add a 45 degree fitting, to make it at more of a down angle towards the pan, and of corse fix any kinks their might be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicotine &raquo;</TD></TR><TR><TD CLASS="quote">how do i shorten the line???? never done it before...
also, what is a fire sleeve? is it like the heat wrap they do on the down pipes?</TD></TR></TABLE>
Shorten the line by wrapping it with tape first then cutting it at the desired length then reinstall the fitting.
Old Jul 3, 2007 | 04:37 PM
Mr.Death's Avatar
Default Re: oil return line..HELP!!!!! (EG civic)
It doesn't look that bad at all. It looks similar to my return and It's been that way for almost 3 years.
Old Jul 3, 2007 | 06:03 PM
boostedblkef's Avatar
Default Re: oil return line..HELP!!!!! (Mr.Death)
as long as your line entering your pan is the lowest point your fine sometimes with chargepipes and such they have to be run in a weird way
Old Jul 3, 2007 | 06:36 PM
nicotine's Avatar
the last few inches of the line run parallell to the earth..not "down"...
so im gonna see if i can find a 45 degree tomorrow and see what i can do, if anything..
i may have to reverse how my turbo sits ....that'll be fun and a half....ugh....
any other suggestions?
also, my concern is that this may not be letting oil out fast enuff. hence why the last turbo's seals blew up.
this turbo is fine for a few days, now, a SMALL touch of smoke out the tail pipe...not entirely blue, but i dont wanna let it progress (parked the car till i fix it).
dont feel like blowing up a gt35r :\
Old Jul 3, 2007 | 06:44 PM
numbnuts22715's Avatar
Id get the 45degree and try to shorten it.
As long as its running towards the bototm of the car, with no links and no upward changes in direction, then the oil return line isnt your problem.
How are you sure that it's your problem anyway?
Old Jul 3, 2007 | 06:46 PM
nicotine's Avatar
im sure it's my problem, cuz my last turbo was blue smoking from day 1, and got progressively worse.
i got this turbo from JRP with restrictor (which is ON the turbo..should it be ON the turbo, or at the oil feed adapter??)
and there was no blue smoke for a few days. yesterday i noticed a LITTLE, so i shut the car down and parked it till i figure out whats up.
Old Jul 3, 2007 | 06:49 PM
the restrictor can be anywhere on the line going to the turbo. It restricts the flow of everything after it.
Have you unplugged the oil return line to make sure oil is making its way out of it?
Old Jul 3, 2007 | 06:58 PM
nicotine's Avatar
that's what im gonna do in the am....it goes flat with the earth a few good inches before the oil pan....the bung doesnt point down....
i just get this feeling thats what it is..that..and a few people say it's wrong for sure :S
Old Jul 4, 2007 | 02:57 PM
nicotine's Avatar
so i pulled the oil return line off. there was a good chunk of oil that bled down from the line itself once removed..
so i really dont think it was draining right
got some new fittings coming in the next day or so...i hope it works.
i ordered another bung also as i have another oil pan..gonna do a slight upward angle on the bung..
wish me luck..any other help appreciated.
Boosted_Coupe
May 20, 2007 12:15 PM
biada1
Dec 9, 2006 06:35 PM
93turbotegSAV
Aug 29, 2006 02:44 PM
birz
Jun 4, 2004 06:03 AM
