Oil Return Line
I just recently purchased an oil return line from flamenco-T but I dont know how to assemble it. I tried to get the red things on the line but it just wont fit. Is there a trick to it or am I just not man enough to get it on? Thanks for any advice.
Re: Oil Return Line (mike34655)
Don't let the ends fray. Keep some of the tape around the end to assist you in inserting it into the hose-end then pull off the tape. If it frayed, then you'll have to recut the end.
-10AN is a lot easier to work with than smaller lines b/c the rubber can flex. |
Re: (DaX)
Thanks for the replys. I finally got it together.
