DRAG owners: Please post pics of your oil return line...
I just got a used drag kit and I needed to see how you guys did your oil return lines. So far I see an L shaped peice of pipe less than 1/2 in diameter and around a 3-4 inch garden hose thingy. Are these the oil return lines for the drag kit???
Re: DRAG owners: Please post pics of your oil return line... (boredracer408)
"c) The drag kit comes with 1/2" female NPT flange and also a 1/2" NPT male brass barb. Weld the supplied L-shaped pipe included for the oil drain in the hole drilled. This can be done either with JB weld or professionally welded (highly recommended)."
-- this is in my article which is stickied at the top of this forum. You can also see a picture of the rubber hose in the article. So , yes the "L shapped piece" and the "garden hose thingy" are used for the oil return line. The picture in the article doesn't show the supplied fitting welded in the pan because we used our own.
KC GSR
02-04-2003 02:33 PM
