Oil return issue....
Old Dec 23, 2007 | 06:38 PM
mitsuman's Avatar
Default Oil return issue....
Ok on my last turbo set up i tapped the oil pan with a barbed fitting to match that size of the fitting off my old turbo, also i had a ram horn so i was able to run the return with out a problem. this is a really tight squeeze and this is the best i could do with what i had at the moment.
will this work or is it too much of an angle?
not looking to get flamed for the looks, im not worried about that, i know it will not leak and thats all i care about. Thanks.
Old Dec 23, 2007 | 06:41 PM
ChampWhiteTegra's Avatar
Default Re: Oil return issue.... (mitsuman)
looks like it may puddle up. i duno what else u could do tho
Old Dec 23, 2007 | 06:44 PM
boosstboy's Avatar
Default Re: Oil return issue.... (ChampWhiteTegra)
i hope you have set of extra seals for that turbo, that kink in the return line will cause too much negative pressure in the turbo.
Old Dec 23, 2007 | 06:50 PM
eh3 93's Avatar
Default Re: Oil return issue.... (boosstboy)
Clock the turbo 15 degrees.
Old Dec 23, 2007 | 06:52 PM
Default Re: Oil return issue.... (eh3 93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh3 93 &raquo;</TD></TR><TR><TD CLASS="quote">Clock the turbo 15 degrees.</TD></TR></TABLE>
duh im retarded yes clock it and u should be ok
Old Dec 23, 2007 | 09:45 PM
mitsuman's Avatar
dammit i just mounted everything!
thanks guys
Old Dec 23, 2007 | 10:39 PM
RCautoworks's Avatar
And get a different line, if thats the one ment for sinks.
Old Dec 23, 2007 | 11:05 PM
1sic3dr's Avatar
Default Re: Oil return issue.... (RCautoworks)
just cut about 1inch out of the line and it will work but if you have to you can cut more out of it. i had to do it with my old turbo set-up. just make sure it is going down so it can drain back.
Old Dec 24, 2007 | 12:02 AM
D16SohcVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman &raquo;</TD></TR><TR><TD CLASS="quote">Ok on my last turbo set up i tapped the oil pan with a barbed fitting to match that size of the fitting off my old turbo, also i had a ram horn so i was able to run the return with out a problem. this is a really tight squeeze and this is the best i could do with what i had at the moment.
Yes, you should definately clock that. My old oil return line looked a lot better then that and was a lot higher, but still dipped a bit. It was fine on normal drives, but when I got on the freeway. Man, it was like a morning fog on a sunny afternoon day.
Old Dec 24, 2007 | 06:16 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">And get a different line, if thats the one ment for sinks. </TD></TR></TABLE>
Old Dec 24, 2007 | 09:02 AM
mitsuman's Avatar
Default Re: Oil return issue.... (Autoworks)
will be clocking today.
what lines do you suggest? i ran this same type hose on my last set up without problems.
Old Dec 24, 2007 | 09:41 AM
90sedan's Avatar
QFT again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman &raquo;</TD></TR><TR><TD CLASS="quote">will be clocking today.
I can only recommend steel-braided line, but any high-temp thick rubber lines would work for it. But I've never been a fan of just using a rubber line as it wouldn't protect the line much if you were to hit something, or have something fly up there.
I personally would worry to much about it, then again oil is crucial to your motors life.
sheepey
Apr 22, 2010 09:33 AM
boostedcoupe1
Feb 20, 2008 01:55 PM
J_Pemb
Jun 30, 2005 08:01 PM
dturbo
Apr 5, 2005 03:44 PM
