turbo b16 t3t4 smokes when i shft (out the exhaust) turbo oil line sizes wrong
Old 03-19-2004, 03:30 PM
Neukin's Avatar
Default turbo b16 t3t4 smokes when i shft (out the exhaust) turbo oil line sizes wrong
i think its the oil sending line (too large ) i dont know the an size i forget. its 4.5 cm (the circumfrence ) think its -6an. will too large of a sending line backup the oil in the turbo? seems like it would if not then what else could be the problem i know the return is like 7.5 cm in circumfrence dont know what size. thanks
Old 03-19-2004, 03:32 PM
DaX
DaX's Avatar
What egine/OBD/EMS?
Old 03-19-2004, 03:43 PM
Nextelbuddy's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (out the exhaust) turbo oil line sizes wrong (toyosupr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr &raquo;</TD></TR><TR><TD CLASS="quote">i think its -6an. </TD></TR></TABLE>
anything bigger than a -3an feed line will require oil restrictors or you will eventually blow the seals in the turbo
Old 03-19-2004, 05:14 PM
Neukin's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (nextelbuddy)
ahhhhh!!! not good
thanks
obda pr3 jdm ecu smc500
Old 07-28-2004, 06:47 AM
turbo'd integra LS's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (CosmoE36)
how long before it will blow your seals? if the turbo didnt smoke as much when i first got it and is smoking more now could that be it??
Old 07-28-2004, 08:10 AM
Neukin's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (turbo'd integra LS)
just depends on how much you beat on it, id guess, take it easy and should be fine for awhile
Old 07-28-2004, 11:06 AM
m R g S r's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (toyosupr)
Well oil pressure is rpm dependant, so if you always take it easy and dont rev out the gnine, the turbo seals won't see a lot of oil pressure.
Old 07-28-2004, 12:11 PM
Rod.'s Avatar
Default Re: turbo b16 t3t4 smokes when i shft (m R g S r)
i had a -6 feed line and my car start smoking bad after boost.
Old 07-29-2004, 09:48 AM
if i put a restrictor on now will it stop most of my smoking and oil burning if i've had the turbo on for about 2-3 weeks??
Old 07-29-2004, 10:50 AM
b20turbojason's Avatar
my buddy that has a 700 hp eclipse said that he used to smoke and leak oil from his turbo inbetween shifts, and he said it was cause he was getting to much oil pressure to the turbo. he was running the oil line from the oil sending unite and the oil pressure would get to high for the turbo in the higher rpm's. so he switch his oil line to his head and the problem went away. i am haveing the same problem and i about to move my oil line also. only thing that i don't understand about that is i thought the oil pressure would be the same no matter where it is on the motor. but then maybe eclipse's are differant.
Old 07-29-2004, 11:06 AM
beepy's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (b20turbojason)
No, the main oil "arteries" in the engine are under full pump pressure, but other parts are under reduced pressure, such as the cam bearings or your VTEC solenoid.
The turbo does not like to see oil pressure. I run -3AN with a 1mm restrictor in the feed, and -8AN for the drain.
Some may say that is overkill, but I had problems with the oil before.
Old 07-29-2004, 02:13 PM
DaX
DaX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turbojason &raquo;</TD></TR><TR><TD CLASS="quote">only thing that i don't understand about that is i thought the oil pressure would be the same no matter where it is on the motor. but then maybe eclipse's are differant.</TD></TR></TABLE>
Pressure is like voltage...as it passes through a component [read restriction/resitance], you have a drop or "change in potential."
Old 08-03-2004, 09:49 AM
Default Re: turbo b16 t3t4 smokes when i shft (DaX)
man my seals might be shot if its smoking at idle now huh??? it doesnt at first...i leave it idle for a minute or so and the ****** things smokin like crazy.....any ideas??? still waiting for that restrictor but nto sure if thats going to fix a problem like that???turbo i boguht was brand new only used 3 or so weeks...
Old 08-03-2004, 10:05 AM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo’d integra LS &raquo;</TD></TR><TR><TD CLASS="quote">man my seals might be shot if its smoking at idle now huh??? it doesnt at first...i leave it idle for a minute or so and the ****** things smokin like crazy.....any ideas??? still waiting for that restrictor but nto sure if thats going to fix a problem like that???turbo i boguht was brand new only used 3 or so weeks...</TD></TR></TABLE>
I don't Believe they are shot because I had this same Problem. The reason why its starts to smoke after a min or so... is because the oil pressure is much higher in the engine until the oil warms and thins a bit..but with higher oil pressure cause the turbo seals to fail and slip oil into your exhaust then when your DP gets hot ... oil begins to burn off...This happened to me and was told the reason by the guy who rebuilt my trubo...Also he said to use a 3AN feed which controls the volume and I already run a 10AN drain back...OH no more smoke ...People said my seals were gone...NOT...My turbo Guy said the seals are like piston rings so if they are bad they are always bad. Trail and Error is how you get through these problems.. Hope this helps...I need to post the some pics of the difference between the 4AN line and the 3AN line, a big difference in volume not so much the to lower the pressure. But its more of lowering the volume of oil that solved my problem. bump
Old 08-03-2004, 10:14 AM
toolowsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Pressure is like voltage...as it passes through a component [read restriction/resitance], you have a drop or "change in potential."</TD></TR></TABLE>
sounds like your talking more about current than voltage.... Sorry, that just bugs me
Old 08-06-2004, 05:17 AM
Default Re: turbo b16 t3t4 smokes when i shft (Redwidow)
well man i just put on a restrictor and im running a 3AN line...whats a 10AN line in inches?? My line is 3/4" on the return....i was told by someone that i could have floated my seals in the turbo and messed them up? what oil you runnin?
Old 08-06-2004, 06:09 AM
DaX
DaX's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like your talking more about current than voltage.... Sorry, that just bugs me </TD></TR></TABLE>
Current is equivalent at each point in a series circuit [no matter how much restriction there is]. Voltage drops through each restriction in a series circuit and then increases at a place where energy is put into the system [like a battery, or oil pump], so the sum of all the voltage or potential drops is equal to zero.
Old 08-06-2004, 06:57 AM
i my honda
Global Mod
White Smoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your talking more about current than voltage.... Sorry, that just bugs me </TD></TR></TABLE>
Not really. The way he used it sounds nothing like current. Dax is right about the current being equivalent in a series circuit. What is not right is saying that the oil flow in your motor travels in a series circuit. It’s a compound (complex) circuit; it has both series and parallel junctions.
Actually the turbo feed/return lines are in parallel with the rest of the oil system AFTER the oil feed port. So the current/flow would not be the same throughout the system. That is what you want!
If you run a smaller line than there will be more resistance in the feed/return lines witch will result in less current/flow through the turbo lines witch will use/see less voltage/oil.
Hope this helps
Old 08-06-2004, 08:24 AM
civictypenos's Avatar
where to get these restrictors at?
Old 08-06-2004, 09:15 AM
Redwidow's Avatar
Default Re: turbo b16 t3t4 smokes when i shft (civictypenos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo’d integra LS &raquo;</TD></TR><TR><TD CLASS="quote">well man i just put on a restrictor and im running a 3AN line...whats a 10AN line in inches?? My line is 3/4" on the return....i was told by someone that i could have floated my seals in the turbo and messed them up? what oil you runnin? </TD></TR></TABLE>
Not truely sure on the size comparison of a 10AN. 10-30W synthetic oil...Are you still smoking after burning off what excess oil was left in the DP?
Old 08-06-2004, 11:18 AM
it just smoked a little this morning (the first time i drove it since the resitor was in place) just a little...but my a/f guage is showin rich at start up...but i didnt clean the charge pipes so theres still oil in them....so after i do that i'll have to check er out...im hoping there wont be no oil!! how much oil you go through now??
Old 08-06-2004, 11:19 AM
oil restrictors can be found at this site...
http://www.atpturbo.com/Mercha...e=OIL
Old 08-06-2004, 11:22 AM
Redwidow's Avatar
I'm not sure what you mean...I know you shouldn't be using loosing oil if your problem is fixed. The oil I loose is caught in my perrin Oil Catch can. PCV...
Old 08-06-2004, 12:27 PM
i was using a an6 on a t25,smoked like crazy,couldnt stand it.switched to a an3 and now it only smokes on hard acceleration,but that could also be the old oil still.going to a an3 made a huge difference.
bboyfreeze
04-02-2007 08:38 PM
90hatchblack
03-01-2007 07:57 PM
slo_crx
10-12-2004 05:51 PM
Krayzielix
07-08-2004 04:18 PM
Boostage
01-15-2004 06:23 AM
Quick Reply: turbo b16 t3t4 smokes when i shft (out the exhaust) turbo oil line sizes wrong
