Oil Return Fitting, How deep?
Old May 5, 2004 | 02:16 PM
warwagon's Avatar
Default Oil Return Fitting, How deep?
I tried searching but 56k gets ridiculous!!!! I dont have a motor to look at, i am about to go get a fitting welded into my z6 pan, and was wondering how deep the fitting can go in. I am going to place it about an inch and a half under the lip of the pan.
Old May 5, 2004 | 02:38 PM
Flamenco-T's Avatar
Default Re: Oil Return Fitting, How deep? (warwagon)
This is off of my instruction to install the oil return line kit,
hope this helps
Old May 5, 2004 | 03:09 PM
yellowhonda88's Avatar
Default Re: Oil Return Fitting, How deep? (Flamenco-T)
you dont want it too far down into the pan, otherwise it start to get into standing oil.
Brett
warwagon's Avatar
thats the same fitting i have!!! does it have the prolly half inch of pipe thread on the other side of it?
Old May 5, 2004 | 03:13 PM
warwagon's Avatar
Default Re: Oil Return Fitting, How deep? (yellowhonda88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowhonda88 &raquo;</TD></TR><TR><TD CLASS="quote">you dont want it too far down into the pan, otherwise it start to get into standing oil.
Brett</TD></TR></TABLE>
yeah, flamenco-t got me hooked up thanx!!!!
Old May 5, 2004 | 03:22 PM
warwagon's Avatar
and bam
a hacksaw and my rabbit pumping turned my two sided fitting into that woo hoo
Old May 5, 2004 | 05:58 PM
warwagon's Avatar
and she's welded on now!!!!!!!
Old May 5, 2004 | 08:59 PM
12thstreetjunkman's Avatar
Default Re: (warwagon)
wow, I am amazed at your welding skills, who did you take it too
Old May 5, 2004 | 11:52 PM
Cramerox's Avatar
Default Re: (12thstreetjunkman)
hahah that is a clean weld...nice job.
Old May 6, 2004 | 04:52 AM
warwagon's Avatar
daniel f. for free
Old May 6, 2004 | 06:07 AM
92HB_HB's Avatar
is tha migged or tigged??
Old May 6, 2004 | 06:15 AM
jmagner's Avatar
Warwagon, is that an aluminum AN fitting? How did you weld that to a stock oil pan, and flamenco, is that a steel or aluminum fitting? What catalog can you find steel AN fittings in?
I'm wondering because I just had this done and I had to have a 1/2" steel pipe bung welded into the pan so we could screw in a 1/2" to -10AM union.
Old May 6, 2004 | 06:23 AM
FwdCivicHatch's Avatar
you want to put it as far up as you can while still being able to weld the top-side of the fitting.
Old May 6, 2004 | 07:02 AM
B18Flip's Avatar
Default Re: Oil Return Fitting, How deep? (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">Warwagon, is that an aluminum AN fitting? How did you weld that to a stock oil pan, and flamenco, is that a steel or aluminum fitting? What catalog can you find steel AN fittings in?
I'm wondering because I just had this done and I had to have a 1/2" steel pipe bung welded into the pan so we could screw in a 1/2" to -10AM union.</TD></TR></TABLE>
the fitting welded to the oil pan has to be steel since the pan is also steel...hit up flamenco-t for all of that stuff
Old May 6, 2004 | 07:27 AM
warwagon's Avatar
Default Re: Oil Return Fitting, How deep? (FwdCivicHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch &raquo;</TD></TR><TR><TD CLASS="quote">you want to put it as far up as you can while still being able to weld the top-side of the fitting.</TD></TR></TABLE>
yeah thats as high up as he could get his torch!!!
and it was just a 1/2" pipe on one side and the 10an on the other i just cut it in half!!!!!
Old May 6, 2004 | 07:57 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">This is off of my instruction to install the oil return line kit, </TD></TR></TABLE>
That pic is IDENTICAL to how mine is welded
Now if only I had a turbo setup to connect the oil return line to
Old May 6, 2004 | 08:15 AM
warwagon's Avatar
Default Re: Oil Return Fitting, How deep? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Now if only I had a turbo setup to connect the oil return line to </TD></TR></TABLE>
i feel ya!!! my manifold should be here tommorow so saturday should be my day
Old May 6, 2004 | 08:18 AM
Br1t1shguy's Avatar
as far up with as little penetration into the pan as possible.
Old May 6, 2004 | 01:16 PM
warwagon's Avatar
Default Re: Oil Return Fitting, How deep? (Br1t1shguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1t1shguy &raquo;</TD></TR><TR><TD CLASS="quote">as far up with as little penetration into the pan as possible.</TD></TR></TABLE>
you said penetration!!!!!!!!!!!!
Old May 6, 2004 | 02:40 PM
DaX's Avatar
DaX
Loved
Community Favorite
I brazed my fitting onto the pan. Works great, and looks smooth as a baby's ***.
si0385.
Oct 22, 2006 09:19 AM
teamV eg
Jun 30, 2006 11:58 AM
skiwithcars
Welding / Fabrication
Jun 29, 2006 01:38 PM
theharlequin
Mar 5, 2006 01:46 AM
Novtecdohc
Aug 31, 2005 04:29 PM
