OIL RETURN ON DRAG KIT!!!!
Old Oct 1, 2001 | 08:10 AM
Mr. Vapor's Avatar
Default OIL RETURN ON DRAG KIT!!!!
Ok fellas,
right now if i am correct i have the oil return being welded into the shallow end of my pan, is this correct? does anyone have a pic of where you welded it? what are the pros cons of having it dump to the deep or shallow end, and will it hurt if i have it going in there? HELP!
Old Oct 1, 2001 | 08:16 AM
Rob03Pro5's Avatar
Default Re: OIL RETURN ON DRAG KIT!!!! (NYb16)
Yes have it at the shallow end.. even if you do have it at the deep end, just keep the bung up high above the oil level.
Old Oct 1, 2001 | 08:37 AM
Mr. Vapor's Avatar
Default Re: OIL RETURN ON DRAG KIT!!!! (Rob92SC)
so it wont hurt to have it at the shallow end?
Old Oct 1, 2001 | 08:57 AM
bigTom's Avatar
it shouldnt matter... just make sure its towards the top of the pan!
Old Oct 1, 2001 | 09:32 AM
D-SPEED's Avatar
Default Re: OIL RETURN ON DRAG KIT!!!! (ek9t)
why put the fitting up high ?
Old Oct 1, 2001 | 09:58 AM
QuickHonda's Avatar
Default Re: OIL RETURN ON DRAG KIT!!!! (D-SPEED)
The fitting needs to be up high to ensure that its above the level of the oil in the pan. If the fitting were below the oil level it would hamper the ability of the oil to drain out of the turbo which would cause oil leakage past the seals and blue smoke.
InTheZoneAC
Apr 7, 2013 06:47 PM
stockgreencivic
Jun 14, 2005 07:27 AM
NyQuiL
Nov 1, 2004 09:33 AM
Sinner
Oct 8, 2004 09:21 AM
Teg4e
Jun 20, 2002 08:34 PM
