DRAG kit Question....
Old Jun 20, 2002 | 12:48 PM
Teg4e's Avatar
Default DRAG kit Question....
What part that comes with the DRAG gen III kit do i specifically need welded onto the oil pan? I've heard it's that 90 degree bending metal pipe, but i've never seen a picture of that pipe welded onto it. Also, one end of the pipe is longer than the other, so which end needs to attach to the pan?
Old Jun 20, 2002 | 12:52 PM
dustin's Avatar
Default Re: DRAG kit Question.... (Teg4e)
That's because nobody uses the POS Drag oil return
Old Jun 20, 2002 | 01:41 PM
Teg4e's Avatar
Default Re: DRAG kit Question.... (dustin)
right.....well that's what I'm using for now. So, anyway, how about some help with this?
Old Jun 20, 2002 | 06:36 PM
oscargsr's Avatar
The part you are talking about is the oil return line from your turbo. What it does is that it lets oil drain back into your oil pan. Becarefull where you weld your return, position it high on the oil pan so that oil can flow out easy with no resistance. The reason for that is that if oil does not flow out easy, oil can get backed up in your turbo and eventually blow seals. So BECAREFULL by the way have fun
Old Jun 20, 2002 | 06:55 PM
SIK IN DA HED's Avatar
New User
HEY! im using it.
Old Jun 20, 2002 | 07:53 PM
niedejb's Avatar
Default Re: DRAG kit Question.... (dlplayboy)
Heres mine...no welding. Its a -10 AN fitting and elbow from a hydraulics shop. Not from a kit. <$20.
[Modified by niedejb, 10:54 PM 6/20/2002]
Old Jun 20, 2002 | 07:57 PM
SlowB16's Avatar
Default Re: DRAG kit Question.... (niedejb)
I think it is funny how if you get Earls fittings, your setup would be around 50 bucks or so, but the same shtish from a hydrolic store was less that 20!!
Just do as this guy did, but get steel braided hose for the return line, and the feed line as well.
Old Jun 20, 2002 | 08:30 PM
Teg4e's Avatar
mmmm purdy.....
i'm looking into that setup instead of drag's....
Old Jun 20, 2002 | 08:34 PM
Anthony K's Avatar
New User
Get some steel braided line on that thing.
nsxmatt
Aug 31, 2005 09:09 PM
808b18c1boosted
Sep 28, 2004 12:55 PM
HybridKOOP
Jan 22, 2004 03:56 AM
hybrid901
Sep 29, 2002 02:42 PM
Mr. Vapor
Oct 1, 2001 09:58 AM
