Oil question
Old Feb 11, 2014 | 06:03 AM
  #26
Turbo-LS's Avatar
Default Re: Oil question
Its depends on your Oil Clearences like already stated as to what weight you want to run. Living in a warmer climate will allow a little thicker with stock clearence. My motor is loose i run 20w50 Joe Gibbs XP6 synthetic motor oil. Its not cheap but When your dealing with a motor you drop thousands of dollars into why cheap out on oil. The Joe gibbs has lots and lot of what matters most in an engine, particularly in the vtec engines.
You'll see cam journal wear on todays standard oils as the zinc and phosphorous addatives are drastically decrease in todays oils and there just isnt enough protection.
Old Feb 11, 2014 | 06:56 AM
  #27
Freemananana's Avatar
Well, my clearances are stock. Probably worn a little too. So that was my question. The warmer climate is also a big thing. I guess I will call them up and see what they would suggest. Usually companies like this are all about suggesting the proper product for a specific set up.
Old Feb 11, 2014 | 07:15 AM
  #28
LightningTeg's Avatar
Community Builder
I run 20-50W Kendall GT1, or VR1 in the summer , Delvac 15-40 in the cooler weather.
Directly from the Hot Rod article, June 2006, When Good Cams Go Bad:
SH API oil rating 1996
zinc = 0.130%, 1130ppm (parts per million)
phosphorous = 0.120%, 1120ppm
SJ API oil rating 2001
and
SL API oil rating 2004
zinc = 0.110%, 1100ppm
phosphorous = 0.100%, 1000ppm
SM API oil rating 2005
zinc = 0.087%, 870ppm
phosphorous = 0.080%, 800ppm
SM API oil rating 2007
zinc = 0.060%, 600ppm
Cosworth Racing Oil
zinc = 0.125%, 1250ppm
phosphorous = 0.115%, 1150ppm
Shell Rotella T CI-4
zinc = 0.140%, 1400ppm
phosphorous = 0.130%, 1300ppm
Pennzoil 25W-50 Racing Oil
zinc = 0.196%, 1960ppm
phosphorous = 0.180%, 1800ppm
Quaker State Q Racing Synthetic
zinc = 0.200%, 2000ppm
Obviously, the 4 oils above do not have an API rating for newer engines. Their rating would be SH or SG. Pennzoil Racing is SG. Rotella is SH/SJ.
From the Kendall website for GT-1, which I've used since 1964 and now can no longer use for fear of cam and lifter damage:
additional spec. for oils of interest:
Kendal GT-1 green 40W, old mfg.
phosphorous = 0.200%, 2000ppm
Kendall GT-1 amber 40W. Older green GT-1 used in Thunder and still have 5 quarts of the green oil left. New GT-1 color is amber. Green GT-1 has high zinc and phosphorous content. Amber GT-1 has low content.
zinc = 0.104%, 1040ppm
Kendal GT-1 amber 30W. Older green GT-1 was used in the other Olds engines.
Kendal GT-1 amber 20W-50
zinc = 0.113%, 1130ppm
Kendal GT-1 amber 10W-40
zinc = 0.086%, 860ppm
Also:
Chevron Delo 400 10w-30
phosphorous = 0.126%, 1260ppm
Chevron Delo 400 10W and 20
zinc = 0.127%, 1270ppm
phosphorous = 0.114%, 1140ppm
Chevron Delo 400 30, 40, and 50
phosphorous = 0.116%, 1160ppm
Chevron Delo 400 Synthetic 0W-30
zinc = 0.130%, 1300ppm
Chevron Delo 400 Synthetic 5W-40
zinc = 0.151%, 1510ppm
phosphorous = 0.136%, 1360ppm
Valvoline VR1 20W-50 Racing oil
phosphorous = 0.120%, 1200ppm
sulfated ash = 1%
calcium = 0.250%, 2500ppm
NOACK % off @ 250C = <15% (This rating tells how much oil will be lost as vapor at high operating temperatures. 15% is the break point. 10% is very good. 5% is fantastic.
Valvoline Not Street Legal Synthetic Racing Oil
zinc = 0.120%, 1200ppm
Valvoline Not Street Legal Conventional Racing Oil
phpsphorous = 0.120%, 1200ppm
Royal Purple Synthetic Racing 21 Oil 5W-30
zinc = 0.1961%, 1961ppm
phosphorous = 0.1130%, 1130ppm
calcium = 0.2994%, 2944ppm
Royal Purple Racing 41 Oil 10-40w synthetic
zinc = 0.1901%, 1901ppm
phosphorous = 0.1171%, 1171ppm
calcium = 0.2843%, 2843ppm
Royal Purple 15-40 w Synthetic
zinc = 0.1213%, 1213ppm
phosphorous = 0.1126%, 1126ppm
calcium = 0.2961%, 2961ppm
Harley Davidson 20W-50 Synthetic
zinc = 0.1068%, 1068ppm
phosphorous = 0.997%, 997ppm
calcium = 0.1342%, 1342ppm
STP oil treatment
zinc = 0.1959%, 1959ppm
phosphorous = 0.1814%, 1814ppm
calcium = 0.1371%, 1371ppm
Redline Synthetic 10W-40
zinc = 0.1350%, 1350ppm
phosphorous = 0.1371%, 1371ppm
calcium = 0.2782%, 2782ppm
Redline Synthetic 10W-30
zinc = 0.1407%, 1407ppm
phosphorous = 0.1340%, 1340ppm
calcium = 0.2869%, 2869ppm
Redline Synthetic 5W-30
zinc = 0.1421%, 1421ppm
phosphorous = 0.1419%, 1419ppm
calcium = 0.2917%, 2917ppm
Mobil 1 Synthetic
zinc = 0.1376%, 1376ppm
phosphorous = 0.1223%, 1223ppm
calcium = 0.2937%, 2937ppm
Old Feb 11, 2014 | 10:08 AM
  #29
Alex Trebek's Avatar
I ran Torco 5w-30 and now run Amsoil 5w-30, in my D16.
Old Feb 11, 2014 | 03:29 PM
  #30
ls joker's Avatar
Loved
do you have aftermarket higher lift camshafts.
i ran eneos 5w30, untill i put gsc n1's in. now its evident that, that oil is not efficient. the higher oil temps are makin it hard to keep the ect's down. ect's have been higher ever since i swapped the cams. thus inadequate oil properties, weight, and zinc.
Old Feb 12, 2014 | 04:56 AM
  #31
Flr Power's Avatar
ECT's have nothing to do with oil. Oil is mainly a lubricant. You changed cams, the engine runs higher ECT, not because of the oil itself.
Old Feb 12, 2014 | 05:06 AM
  #32
Flr Power's Avatar
TheShodan link is kind of old. New oil classification is SN, better for turbo and E85.
http://www.pqiamerica.com/apiserviceclass.htm
File Type: pdf
Old Feb 12, 2014 | 05:12 AM
  #33
ls joker's Avatar
Loved
if the oil temps rise, its just natural that the engine coolant temps are goin to rise aswell
Old Feb 22, 2014 | 09:25 AM
  #34
slowtegkauai's Avatar
Does amsoil Racing series have a good zinc content? I dont see much people running their brand. Or is it not woth talking about?
Old Feb 22, 2014 | 04:28 PM
  #35
ek98gsr's Avatar
Originally Posted by Schister66
*Added to the Forced Induction FAQ page*
Lets keep this good discussion going
Win. This should help some people out.
Old Feb 22, 2014 | 04:34 PM
  #36
ek98gsr's Avatar
http://www.amsoil.com/techservicesbu...t%20tappet.pdf
Old Feb 22, 2014 | 05:26 PM
  #37
h22apwrd95's Avatar
Default Re: Dumb question
Originally Posted by TheShodan
Depends upon how you have the bearings set, (loose or tight), what turbo you're using, and what the use of the car is. Also, the use of E85 has its own properties, so depending upon the use, you may need to avoid a few types of oil.
I typically do not recommend mobile 1 synthetic. For the journal bearing versions, something with good zinc content for the thrust bearings of the turbo..
So, Brad Penn, Valvoline VR1 "blue" oil, are good places to start, as well Shell Rotella oil is good for E85 as well.
This chart gives the better recommendations for oil. although the weights of the oil are a little more tailored for loose-bearing-fit DSMs, the companies and uses are solid.
http://store.forcedperformance.net/m...otor%20Oil.pdf
I have used the Rislone zinc additive for every oil change since I started using E85. I run a standard 10w-30 to achieve optimum oil pressure based on temperature and clearances. It has helped with any oil breakdown and has treated me well for a "local" solution. I am going to be switching to Brad Penn this time around though.
Old Feb 22, 2014 | 11:28 PM
  #38
justYncredible's Avatar
It's wU to the sOLdiEr!
Thanks for the link! Bookmark it since I'm rebuilding my motor I just need to send it out to Laskey for assembly
Old Feb 23, 2014 | 04:46 AM
  #39
b20ricepower's Avatar
http://540ratblog.wordpress.com/2013...-test-ranking/
Read this. Its a long article but very informative on what oil really is the best. Actually, most high zinc content oils didn't perform well at all.
b00sted92
Sep 26, 2013 07:19 AM
EK k kay
Oct 5, 2005 03:07 PM
Under_Pressure
Apr 27, 2005 01:41 PM
T3T495GSR
Dec 12, 2002 10:44 AM
zer0zer0 TypeR
Nov 23, 2002 02:00 AM
