OIL PUMP PROBLEMS!!!!!!!!!
Old Mar 23, 2004 | 10:10 PM
TURBO-TEG's Avatar
Default OIL PUMP PROBLEMS!!!!!!!!!
heres the situation....i have a fully built gsr motor with a T-70 turbo makin approximately 450@wheels 16 psi.....last summer i blew a stock oil pump gear into a million peices so i had the bottomend re-checked and it was fine(balanced).....so i replaced the gear with a prodrive and this past weekend the same thing happened..... anyone have any suggestions.....????????
Old Mar 23, 2004 | 10:53 PM
earl's Avatar
Default Re: OIL PUMP PROBLEMS!!!!!!!!! (TURBO-TEG)
First question is what harmonic balancer are you using? Did you check the pump clearances when you installed the pro drive gears?
Old Mar 23, 2004 | 11:45 PM
TURBO-TEG's Avatar
Default Re: OIL PUMP PROBLEMS!!!!!!!!! (earl)
the first time the stock pump blew i was using a civic type r pulley single belt......then i was told to put the stock 1 back on 3 belt.......and the machineshop checked the clearances on the gears said they were alright.......i drove the car about 2000 miles with the pro drive.....
Old Mar 24, 2004 | 12:16 AM
liam821's Avatar
25 Year Member
Have you contacted pro drive about the problem? What do they have to say?
liam
Old Mar 24, 2004 | 03:07 AM
m R g S r's Avatar
Default Re: OIL PUMP PROBLEMS!!!!!!!!! (liam821)
How high were you revving?
Old Mar 24, 2004 | 07:13 AM
TURBO-TEG's Avatar
Default Re: OIL PUMP PROBLEMS!!!!!!!!! (m R g S r)
i havent contacted anyone yet , i just took it apart last ngiht and im only revving to 9000.......
Old Mar 24, 2004 | 07:40 AM
earl's Avatar
The fact that a ProDrive billet gear can break, really confuses me. It just does not seem possible but I know it happens. Can you post pix of the gear?
When taking the motor apart, did you notice anything funny when pulling the flywheel off the crank? Were any bolts loose? Was the flywheel material under the bolts gauled? Any gauling between the flywheel and the crank? Any problem in this area will cause a shock to go thru the crank and possibly break the oil pump gears.
Old Mar 24, 2004 | 07:47 AM
TURBO-TEG's Avatar
i wil post up some pics in a few hours......everything else is fine......luckily after the first time it happened i installed a pro light (oil pressure light)...... so i didnt wipe out the botom end..... i just have to take it a apart and clean.......but i dont wanna asssemble until i figure out this oil pump problem......or i buy a moroso extranl pump kit....to much $$$$$
Old Mar 24, 2004 | 09:04 AM
TURBO-TEG's Avatar
HERES THE PICS...................
WHATS LEFT OF MY PRO DRIVE GEAR.........
THE HOUSING..........
GEAR AGAIN...........
MY TURBO AND MANIFOLD.............
Old Mar 24, 2004 | 09:49 AM
earl's Avatar
I would really like to hear ProDrive's thoughts on this happening. Something has to be wrong because something is shocking the gears into submission...bent crank snout?...out of balance flywheel or clutch?...harmonic balancer rocking back and forth on the snout?...How does the key look that holds the balancer in place? Will ProDrive warranty this?
Old Mar 24, 2004 | 10:01 AM
TURBO-TEG's Avatar
i taking the bottom end back to the machine shop to have rechecked for a third time...... but my machinist even told me that the bottomend was fine the first 2 times......so we'll see what happens....nothings was bent before and the the key is fine.......
Old Mar 24, 2004 | 10:02 AM
Ri5e's Avatar
How long does it take to spool up that turbo? It's pretty big..
Old Mar 24, 2004 | 10:04 AM
earl's Avatar
Have the machinist put a dial indicator on the snout of the crank and spin the crank in the block. There should be no wobble. Something has got to show up..
Old Mar 24, 2004 | 10:09 AM
USDM 4G VTEC's Avatar
i would take aart that motor completely and clean it on a solvent tank
u never know if some other pieces stay around and cause more damage on ur engine
i say check for clearances....... i might also wanna point out that u should check the pressure releif valve.... use some crocus paper on it to make sure is smooth
are u using a stronger spring on it???
my guess is that maybe the releif valve isnt letting some of the pressur eout and causes the pump to become a lil to pressurize and unstable on 7.5k rpms
what oil pressure u have when u up there???
if not.. then ike someone else said use the right pulley for the motor.. i have spun 3 motor bearings on the rods.. and wonder if having the wrong pulley caused it.. thats why my built motor now has the stock pulley that even tho is like 3 more pds.. i rather be on the safe side
Old Mar 24, 2004 | 10:11 AM
TURBO-TEG's Avatar
Default Re: OIL PUMP PROBLEMS!!!!!!!!! (BG Boost)
my bottom end is bore to a 1.9 litre and 10:1 compression.......starts to spool at about 4000....... and at 16psi by 5500 rpm i cant fry the tires in 1st, 2nd, 3rd even in 4th cruisin at 120kms if i hit it.....it frys....but with a normal tire......on a drag radial i spin 1st, 2nd and a bit of 3rd.......
Old Mar 24, 2004 | 10:14 AM
TURBO-TEG's Avatar
Default Re: (USDM 4G VTEC)
i was using stock pulleys both times it happened........and oil pressure is 70-80 psi full throttle........and both times i bought new oil pumps....
Old Mar 24, 2004 | 03:09 PM
earl's Avatar
Default Re: (TURBO-TEG)
IM me if you find the cause. I would love to figure out how to stop these gears from breaking or at least what causes it. I still can't believe a billet gear can shatter like that.
Old Mar 24, 2004 | 03:22 PM
Turbo E's Avatar
wow...
Old Mar 24, 2004 | 03:27 PM
hybrid901's Avatar
Default Re: (Turbo E 604)
Damn thats awful. I was either going to get a prodrive gear or ATI pulley. I'm glad I picked the ATI. I broke a stock pump last week and I found out today my crank was out of balance but it did last over 3000 miles.
Old Mar 24, 2004 | 07:31 PM
2.2motore's Avatar
Dude, that header is SIIIIIIIICCCCCCKKKK!! who made it for you?
Old Mar 24, 2004 | 07:57 PM
TURBO-TEG's Avatar
Default Re: (Tec1)
thanks alot..........my buddy Marco from Magnus Motorsports built the manifold.....hes the MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 25, 2004 | 02:23 PM
TURBO-TEG's Avatar
Old Mar 25, 2004 | 06:01 PM
rtype11's Avatar
just from looking at the pics it looks like material failure possibly due to a missed heat (normalizing) treatment after machining resulting in material brinelling (brittle/hardening). they should be produced through a sinter process for bulletproof(ness). Should an incorrect install/clearance been the cuase the gear should not have failed in fracture, there should be stretching before failure.
boostedeg22
Nov 9, 2004 05:23 PM
1stGENGSR
40
Jan 15, 2004 07:50 PM
Ek00fbp
Dec 25, 2003 04:54 PM
K20Ahondas
Jan 31, 2003 07:02 AM
Boostless97Lude
Sep 23, 2002 02:44 PM
