Oil Pressure question
Old Aug 3, 2003 | 05:48 PM
TurboCX's Avatar
Default Oil Pressure question
I was wondering what the oil pressure should be at idle for a GSR motor. I'm running a tee off of the back of the block with a turbo oil feed line and the electronic oil pressure gauge. At idle I'm getting about 13psi. Does this sound fine or should it be higher?
Old Aug 3, 2003 | 06:17 PM
meanteg's Avatar
New User
Default Re: Oil Pressure question (TurboCX)
At idle, mine reads 25 PSI when oil is at about 160 deg. and 10-15 when oil is at 200-210 deg.
Old Aug 3, 2003 | 06:29 PM
TurboCX's Avatar
Default Re: Oil Pressure question (meanteg)
When I first start the car and let it warm up, I get about 25 psi as well. After I come home from a long ride and I let the turbo timer count down, this is when I usually see the 13psi at idle. I was concerned about that and I didn't really think about the temp. of the oil and how it affected the oil pressure. Thanks for clearing that up and I appreciate your help. Thanks.
Old Aug 3, 2003 | 06:30 PM
333's Avatar
333
I BELIEVE 20 at idle and 60 psi over 3000 rpm.
Old Aug 3, 2003 | 06:32 PM
meanteg's Avatar
New User
that's normal. do you have an oil temp gauge ? When oil gets hotter pressure goes down.
Old Aug 3, 2003 | 06:33 PM
TurboCX's Avatar
Yeah, unfortunately I only have the oil pressure gauge and not the oil temp gauge.
Excusetobooost
Jun 9, 2020 01:19 PM
TeamSeanFTW
Mar 15, 2011 06:41 PM
ProjectBB6
Sep 16, 2009 02:18 PM
Rob97'SH
Feb 9, 2009 10:55 AM
DuNkiN
Feb 22, 2002 05:50 AM
