Oil Pressure??
Old Oct 29, 2005 | 03:05 PM
Vtec5500's Avatar
Default Oil Pressure??
I have a 94 Civic hatch with a type R block and a GSR Head... she is boosted with a greddy turbo off of a bseries kit from greddy with a changed flange to fit a t3 flange on my ss mani. the oil feed line is a -6an t'ed from the oil pressure sending unit, and the return line is a 5/8th steel braded line...
What should the oil pressure on this set up be???
Old Oct 29, 2005 | 07:17 PM
EnzoSpeed's Avatar
Default Re: Oil Pressure?? (Vtec5500)
AN-6 feedline is huuuuuuuge. Do you have a restrictor?
Old Oct 29, 2005 | 07:57 PM
Vtec5500's Avatar
Default Re: Oil Pressure?? (EnzoSpeed)
it reduces to 1/8 npt on the turbo and on the block the t fitting is also 1/8 npt the line is 6 feet long...
Old Oct 29, 2005 | 08:13 PM
Riake's Avatar
on my 3an I max at 75psi and sustain around 62-64 at 4k rpms at 80mph. I would have no clue as to what a 6an would be like, I wonder if the oil pump would flow enough for that line to make what mine does?
Anyone care to shine in?
Old Oct 29, 2005 | 08:26 PM
EVIL Hx Coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec5500 &raquo;</TD></TR><TR><TD CLASS="quote">it reduces to 1/8 npt on the turbo and on the block the t fitting is also 1/8 npt the line is 6 feet long... </TD></TR></TABLE>
I think the line is too thick. You're most likely loosing alot of pressure by running that big of a line for oil feed.
stealthmode62
Oct 3, 2011 06:14 AM
chrisbell37
Feb 3, 2006 06:36 AM
SuzukaBlueAP2
Jul 7, 2003 02:36 PM
MikeMAN
Jul 2, 2002 09:25 PM
Xerxes
Jan 16, 2002 06:53 PM
