Oil pan gasket trouble
Old 08-28-2007, 05:38 AM
TurboEM1's Avatar
Default Oil pan gasket trouble
Hey guys I just dropped my pan and welded up the oil return. I thought I had another oil pan gasket but I dont. I want to get this finished quick. The engine is an OBD0 JDM B16a. I went to the honda dealer and got a new gasket.
Part number 11251-P30-004. This should be correct right?
I need some tips for installing it. I know the torque spec is 7 ft/lbs.
What is the tightening sequence?
I also got permatex ultra grey. Does that go between the gasket and pan, gasket and engine or both? how much do you use?
Any other tips?
Thanks!
Modified by TurboEM1 at 10:01 AM 8/28/2007
Old 08-28-2007, 06:18 AM
mike1114's Avatar
Default Re: Oil pan gasket trouble (TurboEM1)
U can get the gasket at vatozone or any parts store.
Torque spec is actually 9lbs, at least for a GSR motor.
I don't use any permatex on the oil pan gasket.
Tightening sequence is from midlle of pan outward, thats always the tightening sequence for anything that can warp, head, valvetrain, etc......
EDIT....I would invest in a manual for your car if something as simple as an oil pan gasket is giving you trouble.....
george34
11-09-2016 09:44 PM
imadigitalgod
04-08-2010 09:48 AM
miro_gt
06-24-2007 08:02 AM
StreetRacinThug
12-21-2006 08:44 AM
ringgold
18
09-20-2004 04:28 AM
Quick Reply: Oil pan gasket trouble
