Oil Pan fitting for Oil return question...
Old May 11, 2004 | 11:16 PM
shadow103rd's Avatar
Default Oil Pan fitting for Oil return question...
Can someone show me how they attached the circled fitting to the oil pan?
I was going to weld it but the fitting is made out of steel and if im not mistaken our oil pans are made out of aluminum and I asked a professional welder and he told me that you couldnt weld aluminum to steel.
Can someone clarify this for me.
Thanks,
Jon
Old May 11, 2004 | 11:20 PM
david@didrace.com's Avatar
Default Re: Oil Pan fitting for Oil return question... (shadow103rd)
Oil pan is made out of steel, but if you have an aftermarket aluminum one just get an aluminum AN fitting that is the same size.
Default Re: Oil Pan fitting for Oil return question... (10-94-55)
Oh good. That makes things alot easier for me......Thanks
Old May 11, 2004 | 11:22 PM
NOSpeed97's Avatar
The welder guy is correct. You can't weld different metals together. However, they can be bonded with something like JB Weld. That's whats holding my return fitting to my oil pan.
EDIT: Looks like you're setup will look pretty so maybe going the ghetto JB Weld route is not such a good idea for you.
Modified by NOSpeed97 at 12:40 AM 5/12/2004
Old May 11, 2004 | 11:23 PM
Cruiser G's Avatar
Depends what kind of motor you have. I believe most are steel but the d16y8 is aluminum.
Old May 11, 2004 | 11:28 PM
Charles B.'s Avatar
Default Re: Oil Pan fitting for Oil return question... (Cruiser G)
this is how mines is done
Old May 11, 2004 | 11:34 PM
Just Checking In's Avatar
Default Re: Oil Pan fitting for Oil return question... (CharlesInTurbocharge)
Are the b series pans really made out of steel? Sounds feels and looks like aluminum to me??? Time to break out the magnet.
Old May 12, 2004 | 11:03 AM
Default Re: Oil Pan fitting for Oil return question... (Just Checking In)
This will be going into a d16y8.....can someone confirm that its made out of aluminum or steel.
Thanks
Jon
Old May 12, 2004 | 11:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
Positive. I had my fitting torch welded [brazed] on.
Old May 12, 2004 | 11:45 AM
Flamenco-T's Avatar
D16Y8 is made out of aluminum. I have the weld on fitting available in Steel and Aluminum.
Just mention that when you place your order..
Stan
Old May 12, 2004 | 11:55 AM
Default Re: Oil Pan fitting for Oil return question... (Flamenco-T)
Thanks stan. I am looking at getting that piece the same as the oil pan for ease of installing/welding.
Thanks Stan
Jon
delslow45
Apr 3, 2011 07:14 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
EkHatch1
Dec 9, 2004 08:25 PM
Sinner
Oct 8, 2004 09:21 AM
