Oil in my intercooler?
Old Nov 19, 2003 | 05:09 AM
VanHonda's Avatar
Default Oil in my intercooler?
Well I pulled apart my intercooler piping about a week ago, and noticed a bit of oil on the cool side of the intercooler. The turbo is clean, as well as the hot side pipes. The Turbo itself is a precision sc34 which is brand new with about 5000 miles on it. There is also a buildup of oil under the BOV. The motor is a B16 with wiseco 9:1 pistons and eagle Rods. Any ideas? I am hoping the turbo seal is ok
Old Nov 19, 2003 | 07:26 AM
rjardy's Avatar
Default Re: Oil in my intercooler? (VanHonda)
hows your drain line looking?
Rob
Old Nov 19, 2003 | 07:57 AM
1dumbscreenname's Avatar
sounds to me a seal is shot, thats what it was when i needed a rebuild
Old Nov 19, 2003 | 08:30 AM
showtymers619's Avatar
* B A N N E D *
Default Re: Oil in my intercooler? (1dumbassscreenname)
got a restrictoer on your feedline?> if not your seals gone
Old Nov 19, 2003 | 09:00 AM
VanHonda's Avatar
Default Re: Oil in my intercooler? (ShowTymers619)
Drain seems to be fine...I had a clear line on for a while and it seemed fine...just a little oil running at idle, but much more when the engine revved.
How much will it cost me to get a new seal? is it something I can replace myself?
Is it really possible to have a seal go bad after only 5000 miles?
Old Nov 19, 2003 | 09:02 AM
baddassduramax's Avatar
but wouldnt you think there would be oil on the hot side of the IC also? why is it just on the cooler side? sounds a little wierd to me
Old Nov 19, 2003 | 09:06 AM
VanHonda's Avatar
Default Re: Oil in my intercooler? (civicb18)
I thought the same thing, thats why i didnt think it was the seal...If it matters the engine was running with a lot of piston slap...loose tolerances, that is the reason i am pulling it apart. The pcv isnt run back into the turbo inlet either, but the hot side is completely dry...it wouldnt be hot enough to have the oil vaporized would it so it condensed on the cool side?
Old Nov 19, 2003 | 09:24 AM
30psi Teg's Avatar
Maybe it was just oil from when they process mandrel bends or just some that happend to be in the intercooler does it look like motoroil?
Just a thought anyway.
Old Nov 19, 2003 | 09:28 AM
VanHonda's Avatar
Default Re: Oil in my intercooler? (30psi Teg)
Unfortunately it is motor oil...The piping was allready off the car once for the engine build.
Just had a thought...the turbo, and new engine were broken in with regular oil, and this seems to have started after I switched to synthetic...Mobil 1 15-50, the turbo stuff...could this be part of the problem..would it go away maybe if I went back to regular oil?
Thanks for the replys
Craig
Old Nov 19, 2003 | 12:50 PM
VanHonda's Avatar
bump
Old Nov 19, 2003 | 02:37 PM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">got a restrictoer on your feedline?&gt; if not your seals gone</TD></TR></TABLE>
so anyone that doesent run a restrictor on their feed will blow their seals??? huh...
Landon
Old Nov 19, 2003 | 04:07 PM
DelSlowTurbo's Avatar
Default Re: Oil in my intercooler? (jerseykid609)
what if you have oil on your turbos air inlet, but not at the throttlebody?
Old Nov 20, 2003 | 03:40 PM
Default Re: Oil in my intercooler? (DelSlowTurbo)
bump
Old Nov 20, 2003 | 04:25 PM
JrCRXHF's Avatar
Default Re: Oil in my intercooler? (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE>
from what i have been told yes for the most part but i did not try it with out i just welded the end and put a 1/16 hole and i have been fine
Coheed
Sep 29, 2009 04:07 PM
servion
Apr 6, 2003 01:26 PM
SoulSurfer
Dec 18, 2002 07:45 AM
shadowdawn
Jun 27, 2002 02:12 PM
JohnShaft
Oct 13, 2001 03:49 PM
