no threads on the oil feed!!
Old Mar 15, 2003 | 12:50 PM
boostin b16's Avatar
Default no threads on the oil feed!!
i just bought a t3 turbo and the oil feed hole has no threads!! the two holes around the oil feed have threads like you can put a flange on it but not the oil feed hole is threadless. does anyone know where to get the oil feed flange from? i have seen them online in the past, but where?
boostin
UberTeg's Avatar
Default Re: no threads on the oil feed!! (boostin b16)
tap it
Old Mar 15, 2003 | 12:55 PM
Default Re: no threads on the oil feed!! (UberTeg)
tap it
how? i f you tap the center section of the turbo all of the metal shavings will fall into the housing and **** up my turbo!
Old Mar 15, 2003 | 01:24 PM
UberTeg's Avatar
stuff something in there, and when ur done, ,flush it out with oil.
Old Mar 15, 2003 | 03:36 PM
mamaboy's Avatar
http://www.roadraceengineering.com/f...andgaskets.htm
should help ya out
Old Mar 15, 2003 | 05:41 PM
kenbdSi's Avatar
Default Re: no threads on the oil feed!! (mamaboy)
Get a oil feed flange. You can tap it but you might run the chances of getting shavings in inside the feed hole.
Old Mar 15, 2003 | 05:44 PM
UberTeg's Avatar
Default Re: no threads on the oil feed!! (kenbdSi)
do it right and tap it. Flanges leak and take gaskets.
Granty Boy
Jun 4, 2010 07:52 AM
Chee_dog
Aug 30, 2007 11:10 AM
RuthlessEF-9
Feb 22, 2006 05:19 PM
Mr. Softee
Sep 2, 2003 02:32 PM
NeXtLeVeL_TyPe_R
Apr 15, 2002 10:07 PM
