oil feed source???
Old Jun 3, 2003 | 09:51 AM
flip1199's Avatar
Default oil feed source???
is this a bad idea? if so where else can i get my feed source from?
Old Jun 3, 2003 | 10:13 AM
B18EG6's Avatar
Default Re: oil feed source??? (flip1199)
Well if you have an oil pressure gauge then you dont need the stock oil pressure sensor... all it does is activate the light in your gauge cluster. It wont do anything if you remove it for the feed for the turbo.
just make sure you keep your eye on the oil pressure gauge and check oil level often.
Old Jun 3, 2003 | 11:09 AM
crazychickenhead's Avatar
i ran my oil feed off the head on my nonvtec heads. i put a guage on the line and it was always at 5-10psi... perfect for the turbo. there's two hex caps under the distributor on the b18a/b and b20b/z heads. honda put them there to close the holes after they line bored the head.
Old Jun 3, 2003 | 11:39 AM
B18EG6's Avatar
Default Re: (crazychickenhead)
I could be totally wrong... and correct me if i am...
But i dont think 5 psi is enough to lubricate something spinning at those crazy RPMs. I dont know if it would be a wise idea to tap it on the head, or else everyone else would be doing it too
Old Jun 3, 2003 | 06:09 PM
tony1's Avatar
Default Re: (B18EG6)
5psi is definitely not enough oil pressure for a turbo...
Old Jun 3, 2003 | 07:01 PM
flip1199's Avatar
Default Re: (tony1)
if i did take out the sensor wouldn't my oil light always be on? Also where the hell would i put it? Just leave it hangin? Cuz i damn sure ain't gonna cut it off, cuz imma need to put it back on for cali emmisions.
Old Jun 3, 2003 | 07:04 PM
platinum00's Avatar
Default Re: (flip1199)
that drawing rules.
hehe
but yes. there is nothing wrong with that setup at all.
Old Jun 3, 2003 | 08:03 PM
AP-Signworks1's Avatar
Default Re: (platinum00)
Can't you just use a T fitting? That's what we're doing with my girlfriend's Integra. And that's what we did with the old SC setup on my Maxima. That way, no oil lights.
Old Jun 3, 2003 | 08:07 PM
hybridsol's Avatar
LMAO! What did you get some 3yr old to make that drawing for you?
"Ok class, let's try drawing a oil feed system for a Honda- very good Johnny! But, there's more crayons in the box than black..."
Yes, that will work, I have mine the same way. You can get a female tee and use that also... or the GE oil adapter thing will work...
Damn, that's too funny... [edit- laughing too hard to spell...]
Modified by hybridsol at 12:23 AM 6/4/2003
Old Jun 3, 2003 | 08:30 PM
Flamenco-T's Avatar
Default Re: (hybridsol)
I can make you a kit to where you can run oil feed, and oil pressure gauge as well as stock oil pressure sender. But you can take the stock oil pressure sender out and you will not get a light, if you have a gauge you can use it to your judgement
let me know if I can be any help
stan
Old Jun 3, 2003 | 10:29 PM
BoostedSi's Avatar
Default Re: (Flamenco-T)
i just used 2 brass tee's on the back of the block. One for the gauge and one for the oil feed. It worked fine for 2 years.
DrivinVtec
Oct 16, 2007 07:14 PM
jarven093
Apr 26, 2007 04:47 PM
importdude2000
Jul 6, 2006 04:09 PM
BlueShadow
Apr 11, 2005 01:17 PM
W O T
Jan 29, 2005 08:01 PM
