oil sender fitting
Old Apr 8, 2003 | 10:03 PM
stockgreencivic's Avatar
Default oil sender fitting
does anyone have a picture and/or the size of the fitting needed to T-off the oil pressure sender? what size/parts/fittings are needed?? thanks, let me know!! (for a d16z6)
Old Apr 8, 2003 | 10:06 PM
IMALLSLO's Avatar
Default Re: oil sender fitting (stockgreencivic)
The search buttons your friend, it has been discussed here alot and some threads have full diagrams including sizes and locations. To anwer the question it is a 1/8th npt.
Old Apr 8, 2003 | 10:08 PM
Flamenco-T's Avatar
Default Re: oil sender fitting (proclassracer)
actually 1/8" BSPT..close enough max..
stan
Old Apr 8, 2003 | 10:29 PM
Default Re: oil sender fitting (Flamenco-T)
ok did a search, but i'm still confused a little,
you need a 1/8 bspt male, and then a T connector?? anyone have any pictures?
Old Apr 8, 2003 | 10:48 PM
Arturbo's Avatar
Better than steak
25 Year Member
Old Apr 8, 2003 | 11:02 PM
Pengo's Avatar
or u can always just tap ur block for 1/8 bspt, then you'll be set forever
Old Apr 8, 2003 | 11:10 PM
Default Re: oil sender fitting (Pengo)
ok thanks for the replies, so let me get this straight
the T should have: 1 male 1/8th bspt(to block), 1/8th female bspt for oil pressure sender, and 1 male 1/8th bspt for the oil send line? or can the oil pressure and oil send line connectors be npt?
Old Apr 9, 2003 | 02:27 AM
GOLDBERG's Avatar
whatyd yah guys use too get off that fitting??? my cresent wrench wont really fit..needa buy a 24mm open end i guess
Old Apr 9, 2003 | 04:55 AM
Flamenco-T's Avatar
Default Re: oil sender fitting (GOLDBERG)
nobody makes a Tee with BSPT in it, trust me, I already look through all over egypt for it..
you have to use a BSPT to NPT adapter, then the tee...
stan
Old Apr 9, 2003 | 05:46 AM
PM-Performance's Avatar
15/16 open deeps socket.
i know the size sounds off , but nothing metric fit.
Old Apr 9, 2003 | 12:13 PM
ok,, do you need a bspt adapter for the oil sender and oil feel line too? or can they just screw into a npt?
Old Apr 9, 2003 | 09:25 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockgreencivic &raquo;</TD></TR><TR><TD CLASS="quote">ok,, do you need a bspt adapter for the oil sender and oil feel line too? or can they just screw into a npt?</TD></TR></TABLE>
you can screw the NPT in there, but it's better to get the adapter, to reduce the chance of cracking under torque and leakage...
stan
Old Apr 10, 2003 | 01:14 AM
GOLDBERG's Avatar
ok, so 24mm or 15/16 fits the oil pressure sender i fit my 15/16 socket over it yesterday...and tonight i took it off with my 24mm open end wrench now i just need 1 adapter and i can install this
Old Apr 10, 2003 | 06:14 AM
Flamenco-T's Avatar
I have an adapter, IM me
stan
Old Apr 10, 2003 | 06:32 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Damn Stan, i just bought another one of those, **** was like $9 from Autometer. If i known you had them, i would have got it from you..
Old Apr 10, 2003 | 06:56 PM
IMALLSLO's Avatar
I dont know......Ive used 1/8th npt male to male to the block to a female tee, a 1/8 male to -3 flare for the oil feed line from the tee and screw the oil pressure sender into the tee, for the past 10 years and never had a problem of cracking or leakage. Sold probally 40 kits with the same fittings over that 10 years so if you know something I may not please inform me.
Chris
Old Apr 11, 2003 | 12:03 AM
Flamenco-T's Avatar
well, I have never experienced that problem personally, but I have known a few instances where the torque movement vibration has a too much impact and causes a leaks. but I was running straight NPT to the block for years and it held up fine...
like I stated, you can screw in the NPT in there, and it'll be fine...with BSPT, it's just nicer that the whole thread goes in ALL THE WAY in the block.
stan
Old Apr 11, 2003 | 01:52 AM
GOLDBERG's Avatar
how come whenevrr i ask for bspt here they look at me like i am talking about something alien???none of the automotive guys know what bspt is, nor do they carry it..only npt
B18EG6
Mar 25, 2012 06:20 AM
B18C1CYA
Oct 6, 2009 03:10 PM
totsie7944
May 1, 2008 04:52 AM
97CWITR
Feb 22, 2007 08:36 PM
blufke
Nov 12, 2002 03:20 PM
