AN oil feed line inner diameter?
Old Jun 20, 2005 | 06:11 AM
elpiar's Avatar
Default AN oil feed line inner diameter?
Anyone has a chart of what is the inside diameter (in inch) of the hose for 3 AN, 4 AN, etc.?
Old Jun 20, 2005 | 06:37 AM
IN VTEC's Avatar
Default Re: AN oil feed line inner diameter? (elpiar)
-3AN = 3/16" ID
-4AN = 4/16" ID
....so on and so forth
Altho, it usually ends up a 1/16" smaller than that system would lead you to believe. It also depends on the kind of line you use. Aeroquip AQP and Earl's line is usually 1/16" smaller, while some Goodridge line is the same or slightly larger in ID. You just have to look at the specs in the catalogs.
Old Jun 20, 2005 | 07:59 AM
civicross's Avatar
Default Re: AN oil feed line inner diameter? (IN VTEC)
AN diameter is designated on the OD of a hard line. The inner diameter is smaller.
Old Jun 20, 2005 | 08:18 AM
IN VTEC's Avatar
Default Re: AN oil feed line inner diameter? (civicross)
OK. That makes more sense to me now. I can't believe it's taken me this long to find out what the real standard was.
blakacintegra
Dec 10, 2006 08:52 PM
scartail
Dec 7, 2004 02:27 PM
phiberoptik
Feb 12, 2004 09:11 AM
GSR x13
Dec 2, 2003 10:11 PM
