Oil Feed Line
Old Mar 15, 2004 | 11:53 AM
phreakmang's Avatar
Default Oil Feed Line
Got the earl's oil feed line and having problems.
It does not fit where it's supposed to go, not even close for either adaptor. Is there a different place then on the back of the block that you can hook this up to on a d16y8?
This "complete" turbo kit setup is not so complete..hah.
Getting there though thanks to you guys
Old Mar 15, 2004 | 12:42 PM
tgreaves's Avatar
Default Re: Oil Feed Line (phreakmang)
If your talking about the oil feed for the turbo.. Its a 1/8 bspt fitting on the back of the block where the factory oil pressure switch is.. Im not sure about the kit you have but most people use a 1/8 bspt male to 1/8 npt female adapter and go from there..
Old Mar 15, 2004 | 12:46 PM
tgreaves's Avatar
Default Re: Oil Feed Line (tgreaves)
Forgot to add.. If you do need the 1/8 bspt go to mcmaster.com and put in part number 4860K141
Old Mar 15, 2004 | 03:53 PM
dfoxengr's Avatar
post a pic of what you have and a pic of where youre trying to put it. my money sayd ur going to the wrong place
Old Mar 15, 2004 | 06:44 PM
phreakmang's Avatar
Default Re: Oil Feed Line (hybridvteceg)
no i'm not...
putting it where the sensor switch is, lemme go get a picture for ya though just in case i am
Old Mar 15, 2004 | 06:59 PM
dfoxengr's Avatar
cool if you do end up missing some parts PM me and i can get htem to you cheaply.
Old Mar 15, 2004 | 07:13 PM
phreakmang's Avatar
mmhmm, guessing i need a t fitting that will accept both of these plugs?
Old Mar 15, 2004 | 07:47 PM
RyanEJ8's Avatar
That looks like the knock sensor you have in your hand to me.
Modified by RyanCivic2000 at 12:04 AM 3/16/2004
Old Mar 15, 2004 | 08:03 PM
dfoxengr's Avatar
Default Re: Oil Feed Line (RyanCivic2000)
yeah thats not the oil sending unit. its to the left of the oil filter and thats where the Tee goes. screw that thing back in and move down on the block
Old Mar 15, 2004 | 08:07 PM
phreakmang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats not the oil sending unit. its to the left of the oil filter and thats where the Tee goes. screw that thing back in and move down on the block</TD></TR></TABLE>
aaahaha... /me
goes to search further down the block towards the oil filter to the place this is supposed to go *blush*
for reference, will i need any other parts besides that line to hook this up?
Old Mar 15, 2004 | 08:09 PM
dfoxengr's Avatar
pming you now
Old Mar 15, 2004 | 08:32 PM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phreakmang &raquo;</TD></TR><TR><TD CLASS="quote">
aaahaha... /me
for reference, will i need any other parts besides that line to hook this up?</TD></TR></TABLE>
dude, thats kinda funny.
good luck on your project bro
Rob
Old Mar 15, 2004 | 08:34 PM
phreakmang's Avatar
Default Re: Oil Feed Line (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">
Rob
Tell me about it. I'm a computer guru trying to work on a car, it's a tough switch over...good thing there are some really great people on honda-tech that help out IRL and on the forums.
BTW i found the right hole, fit much better...my g/f would be so proud.
Old Mar 15, 2004 | 09:06 PM
Flamenco-T's Avatar
You need a BSPT adaptor for the block.
Check this out..this is off the page for my oil feed instruction kit,
see that Silver fitting between the block and the Tee ?
Hope this helps..
stan
ÁrniMkv
Feb 10, 2012 07:02 AM
stealthmode62
Oct 3, 2011 06:14 AM
zexifiedlude
Nov 22, 2005 11:15 AM
integranator
Apr 24, 2003 09:42 PM
MikeMAN
Jul 2, 2002 09:25 PM
