oil feed line
Old Jul 19, 2014 | 11:59 AM
kendogg981's Avatar
Default oil feed line
I burned a hole through my oil feed line on my wastegate pipe and I was wondering if I could cut it and put a new fiting on the end of it or help me and see what size this oil feed line is so I can get a new one. ive tried doing research on the sizing and have unsuccessful. any help would appreciated.
Old Jul 19, 2014 | 01:23 PM
met's Avatar
met
Default Re: oil feed line
Probably a -4, typically a -3 takes a 9/16 wrench, -4 a 11/16, and -6 7/8.
Just wanted to add that's for earls fittings, if unsure order a few different sizes.
Old Jul 19, 2014 | 06:35 PM
kendogg981's Avatar
Thanks man, mine was a 7/16 wrench that took this off, I thought it was a -4an but wasn't sure and wasn't going to order the wrong part. Do you think I can cut it and order new fitings?
Old Jul 19, 2014 | 10:17 PM
wantboost's Avatar
Who is Mr Robot?
Those fittings are crimped on... so you can't replace them. that style of line won't accept a standard 2 piece AN fitting
Old Jul 20, 2014 | 04:37 AM
kendogg981's Avatar
Okay thanks for the help man
Old Jul 21, 2014 | 09:11 AM
Jason Buechler's Avatar
If you have a NAPA auto by you some of them have the ability to crimp a new end on for you. Should be much cheaper than buying a whole new one.
Old Jul 22, 2014 | 03:46 AM
kendogg981's Avatar
That sounds like a better route thanks
94lsboost
Nov 28, 2004 03:33 PM
GSR x13
Dec 2, 2003 10:11 PM
reXem
Jul 8, 2002 06:31 AM
