oil feed fitting
where can i find oil feed fittings? had a drag 3rd gen kit, need fitting that will go between braided line to a second fitting, and that second fitting goes into the turbo. i only need the fitting that goes from oil line to 2nd fitting. (i think they are different sizes on each end)
plus i also need a Tial 38mm fitting, it's a two piece fitting - one screws into the wastegate and the other is a nipple which goes over that one, i need the one that screws into the wastegate.
stan at fast turbo is awesome. i just bought some hardware from him and will go back for more. if you can't get help from him, which i doubt (he answers the phone himself), try http://atpturbo.com/
feed line should be -3AN, retun line is -10AN. its kinda hard to tell what you need from your description. the turbo should have a 1/8" npt feed port. most stainless lines have AN hose ends. so for the feed you would have a 1/8"npt -> -3AN fitting installed on the turbo, and then connect the feed like to that.
hit up stan or check out http://www.anplumbing.com for any fittings you might need.
here we go
something like this: so the bottom is 1/8"npt which screws on to the turbo
and the top is -3AN for the feed line, and it has to have a curve tip to seat properly. correct?
i origonally had a 90 degree but it was a bitch working with the damn thing cause i would have to pull line to tighten. couldn't take off from first blown turbo. why 45 or 90?
