a couple ?'s(turbo oil line & wastegate clearance
a couple ?'s(turbo oil line & wastegate clearance)
my first question,im putting a -4 oil feed line on my new turbo, i ordered the line and told them i wanted teflon lined and i got a rubber lined feed line(summit part # rus-632000) is this ok to use or is the rubber line inside gonna start to breakdown due to the heat?
my second question, is anyone runnin a inline pro manifold with a tial wastegate 35mm on a DC2 integra? im just trying to figure if the wastegate will fit under the hood or if i got to trim the under side of the hood or just get a differant wastegate all together.
thanks
thanks
Re: a couple ?'s(turbo oil line & wastegate clearance) (nekkedR)
the WG should fit fine...you may want to change the top nipple into a low profile one and you'll be even better.
On the line, I never used a rubber lined as an oil feed line, tehy may collapsed under vacuum, not that there will be any vacuum unless you're running dry sump. But the heat and the pressure is usually enough for me to use teflon lined for feed line. Plus I never used a -4, it's too big IMO for feed line.
stan
stan
xxxmikenicexxx
05-17-2006 11:09 AM
