oil drain system
Old May 9, 2009 | 07:49 PM
hondaequikppd1's Avatar
Default oil drain system
hey peeps, im having a ongoing problem with my oil drain system. First i had a steel elbow that came w/ my turbokit welded to the oil pan, that started to leak at the base of the tube at the weld/pan i then changed that to an adaptor secured into my oil pan w/ a nut and a silicone hose leading to the turbo, it was ok w/ no leaks until like a week later, and started to leak it leaks right at the base of the adaptor as well, can you guys help. what type of drain system do you guys have? does the oil pan build up pressure to cause that to leak?
Old May 9, 2009 | 07:54 PM
fastcody1's Avatar
Default Re: oil drain system
get some one to weld a bung- not an elbow and you should be fine
Old May 9, 2009 | 07:59 PM
hmm ok, yeah never thought of that, you mean like a threaded nut/bung and the adaptor/hose goes to that?
Old May 9, 2009 | 09:02 PM
omiehomie's Avatar
yes x2
vibrant has something "analogous" to what your looking for but for o2 sensors..here is a link so you can have an idea of what im referring to
http://vibrantperformance.com/catalo...products_id=71
so you need something similar to this ^^ but for your oil pan
Old May 10, 2009 | 12:23 AM
Originally Posted by omiehomie
yes x2
oh cool yea thanks, ill try to find out the size bung i need, the oil drain hose is i believe 5/8"? so i would need the bung and a male threaded/tapered 5/8barb hose fitting on the end, correct?
Old May 11, 2009 | 10:31 PM
omiehomie's Avatar
sounds about right bud, good luck! post pics!
Old May 11, 2009 | 10:42 PM
cool, well heres the pic of where its leaking, at red arrow any other suggestions? i dont kno the sizes of the adaptors that i need..
ballisticej1
13
Jun 14, 2009 08:50 AM
Dat1BVtecN
Oct 11, 2008 03:47 PM
turbotime
Dec 22, 2005 01:46 PM
conors
Sep 10, 2003 03:43 PM
92JDMSiR
May 3, 2002 08:08 AM
