OIL DRAIN FLANGE Question on drag 3 kit
Old 12-07-2001, 10:00 AM
Mase's Avatar
Default OIL DRAIN FLANGE Question on drag 3 kit
I was wondering if anyone knows the size of the the oil drain flange that comes with the drag 3 kit, I have the kit, but just ordered the earl's fittings, and i know it uses the 1/2 ", and the flange comes in either 3/8" or 1/2" does anyone know the size that comes with the kit? thanks
Old 12-07-2001, 11:01 AM
Flamenco-T's Avatar
Default Re: OIL DRAIN FLANGE Question on drag 3 kit (CDooMe2)
-flange with 1/2" female NPT ( connect to turbo)
-male 1/2" NPT to -10 AN fitting
--10 AN lines
--10An to 1/2" NPT female
-1/2" NPT male fitting to weld in oil pan
Old 12-07-2001, 11:22 AM
bigTom's Avatar
Default Re: OIL DRAIN FLANGE Question on drag 3 kit (Flamenco-T)
--10 AN lines
on the oil pan... i would weld on a -10 male fitting... and then put a -10 female fitting on the hose
Old 12-07-2001, 12:04 PM
Mase's Avatar
Default Re: OIL DRAIN FLANGE Question on drag 3 kit (ek9t)
gotcha, but what im wondering is what size flange does the kit come with? i hope a 1/2 '' cuz thats what i need, so can i just use the flange that came with the kit and screw the earls fittings into it?
Old 12-07-2001, 08:21 PM
New User
TurboSedan's Avatar
Yes I believe it is 1/2" NPT. You will use the 1/2" NPT to -10 AN male-male adapter to connect the hose end/hose to the turbo center section.
carbon fiber coupe
01-15-2010 08:26 PM
Speedra500
09-05-2008 05:59 PM
dubniK
07-26-2003 11:43 PM
Damon B.
01-26-2002 09:51 AM
Quick Reply: OIL DRAIN FLANGE Question on drag 3 kit
