OIL DRAIN FLANGE Question on drag 3 kit
I was wondering if anyone knows the size of the the oil drain flange that comes with the drag 3 kit, I have the kit, but just ordered the earl's fittings, and i know it uses the 1/2 ", and the flange comes in either 3/8" or 1/2" does anyone know the size that comes with the kit? thanks
Re: OIL DRAIN FLANGE Question on drag 3 kit (CDooMe2)
-flange with 1/2" female NPT ( connect to turbo)
-male 1/2" NPT to -10 AN fitting
--10 AN lines
--10An to 1/2" NPT female
-1/2" NPT male fitting to weld in oil pan
--10 AN lines
Re: OIL DRAIN FLANGE Question on drag 3 kit (Flamenco-T)
--10 AN lines
--10 AN lines
Re: OIL DRAIN FLANGE Question on drag 3 kit (ek9t)
gotcha, but what im wondering is what size flange does the kit come with? i hope a 1/2 '' cuz thats what i need, so can i just use the flange that came with the kit and screw the earls fittings into it?
Yes I believe it is 1/2" NPT. You will use the 1/2" NPT to -10 AN male-male adapter to connect the hose end/hose to the turbo center section.
dubniK
07-26-2003 11:43 PM
Damon B.
01-26-2002 09:51 AM
