oil drain back problem
Old May 3, 2005 | 09:45 AM
N20civicB18's Avatar
Default oil drain back problem
I rebuilt my LS engine last year and shortly after I noticed my engine would make a wrapping sound for a second on first start up and the oil pressure would take a second to come in, my oil pressure light comes on for a very quick second, sounds like i just changed my oil filter or something every time is start it when its been sitting for a while, if I start it up, shut it off and start it up again within a few hours its fine. I belive the oil is draining back, now my motor has 80,000miles before the rebuild and has about 12,000 now and I think its time to do something, I never touched the oil pump when I pulled the motor apart but I did prelube the system before initial start, what do you guys think is the cause of my drain back problems? i tried a few different filters, mostly fram but im still getting the same problem.
Kyle
I did post this on Tech but have no responces yet so hopfully you guys will know what causes my drain back problems
Old May 3, 2005 | 10:28 AM
Turbo E's Avatar
wrapping? as is rapping like piston slap?
Old May 3, 2005 | 10:32 AM
Muckman's Avatar
Moderator in Chief
Default Re: oil drain back problem (N20civicB18)
Im not buying your drain back theory. There may be something wrong with your oil system. The oil pump should always get replaced with a new build. Do you have an oil pressure gauge? Its normal for the oil light for 1 sec after initial start up. But anytime after that, it means pressure is dangerously low, <5psi.
Old May 3, 2005 | 11:11 AM
Default Re: oil drain back problem (Muckman)
I thought it was piston slap too and it may be but the oil pressure guage shows low for a second but then goes up to normal specs.
Old May 3, 2005 | 11:17 AM
plus if I crank it for a few seconds to build oil pressure there is no problem, it only happens for more then 1-2 seconds at the most so its hard to belive i would only get piston slap for that short, unless stuff warms up that fast.
Old May 3, 2005 | 12:11 PM
s2kdre's Avatar
why dont you put a new pump on it first? Just in case it is the pump.
Old May 3, 2005 | 01:22 PM
Default Re: oil drain back problem (jdmhonda)
well I was wondering if there is any anti-drain back valves or anything to replace or a specific part in the pump the may of gone bad. it has less then 100k miles on the pump and 70,000 was driven by an middle age lady with all proper maintance done so i highly doubt the whole pump needs to be replaced, I suppose I could pull it apart and check clearances but thats not to fun so I would like to get a good idea of what it could be before I do it.
keepinitrehaal
May 2, 2010 10:08 AM
tico
Jun 21, 2008 01:20 PM
HondaEJ7
Feb 13, 2006 05:18 PM
N20civicB18
May 3, 2005 10:27 AM
89SiR
Jun 9, 2003 02:25 PM
