Oil in compressor side boost pipe
Old Mar 30, 2016 | 06:36 AM
94CivicSi's Avatar
Default Oil in compressor side boost pipe
Non-Honda question, but I'm hoping you someone with FI experience can at least shed some light on a problem.
My Wife has a Volvo V40, 1.9L turbo, 163,000 miles. This is the only turbo vehicle I've ever owned.
I was doing service on it over the weekend and noticed that the compressor housing had a film of oil on the outside. Looking closer, it appeared to be coming out of the rubber connection between the compressor and the boost pipe that runs up and over the engine. I pulled the boost pipe and found oil inside. I then pulled the rubber connection between the intercooler and intake manifold and found oil in there as well.
General google searches seem to indicate that a little oil in there is OK. Enough to leak out of the connector, or to find it's way through the IC, seems like too much to me though.
The car doesn't blow blue smoke and a very basic pressure test at the oil cap doesn't show that there's a PCV system problem. Is this likely an oil seal failure inside of the turbo itself? I believe the model is TD04L.....if that helps.
Old Mar 30, 2016 | 08:27 AM
Masterl1nk's Avatar
Default Re: Oil in compressor side boost pipe
For that milleage, is pretty normal to see some oil inside the compressor housing and/or the boost hoses.
Old Mar 30, 2016 | 10:27 AM
TheShodan's Avatar
Moderator
Yep. Plus, a little crankcase pressure from over time.. Pretty normal.
Old Mar 31, 2016 | 03:56 PM
94CivicSi's Avatar
Thanks guys, much appreciated.
Blue-EM1
Nov 29, 2005 05:23 PM
scartail
Apr 4, 2005 04:05 AM
RacerXI
Jul 28, 2004 08:19 PM
mrx
Jul 13, 2004 02:24 AM
beastyboy81
Mar 15, 2003 11:52 AM
