Oil catch can vs stock pcv!!!!!!
Just woundering if its a good idea to run an oil catch can on my turbo si. What do you guys think about the catch can being ran this way. The catch can that I was looking at has two lines off of it, one line will go to the back of the block and the secound line to my valve cover. You guys think that will work. I am looking to run anyware from 300-350 whp, do you even think i should purchase a can or will i be ok with my stock pcv.
Great write up, I got the idea. Will I be OK then to use the stock pcv on 300-350 wph. Read some honda-tech post and it states if you are runing big numbers to invest into a catch can. Being that my whp gain is not that big do you still recomend the upgrad or can I get away with the stock pcv for know.
TravisBiggie
Apr 13, 2012 04:29 AM
