Oil Breather system
Old Mar 26, 2010 | 03:11 AM
Listerofsmeg's Avatar
Default Oil Breather system
Hi all,
Does anybody have any links or advice on how to create a good breather system on a GSR block? i.e. where to vent (crankcase/head takeoffs) etc? I expect my engine to be producing a good amount of power so would like to have an adequate breather system (with return to sump) in place.
Can anyone help?
Old Mar 28, 2010 | 10:37 AM
TEAM ASSASSIN SI's Avatar
Default Re: Oil Breather system
i used to run a z10 kit to the back of the block but it did not work for me can kept filling up after a full boost passes down the track so i now tapped on to valvecover with 2 12 bongs run to a can with no drain back and so far so good,hope that helps
Old Mar 28, 2010 | 10:49 AM
Turbo-LS's Avatar
2 fittings off the front of th evalve cover for up to 500whp preferably -12an but -10an will work. 500-700 two off valve cover and two off back of block. 700 and up four off valve cover and two off back of block.
no drain back on any of those setups
Old Mar 29, 2010 | 02:59 AM
Why no drain back? thats a bit confusing as i would have always thought that was a good idea?
Do you just drill and tap thes fittings? simple as that? (obviously with appropriate sealer!)
Old Mar 29, 2010 | 04:52 AM
Turbo-LS's Avatar
drain back is not a good idea, alot of moisture goes into the catch can and mixes with the oil. do yuou really want milky oil going back into your motor and contaminating the rest of the oil? and from my experience you shouldnt get much oil in the can to begin with. i get maybe 1/4 cup of oil in about 6 months with two fittings off the front of the valve cover
Old Mar 29, 2010 | 04:57 AM
Ahh i see your point! Thanks
Id hope not to be breathing too much oil either on a fresh build!
Old Mar 29, 2010 | 12:45 PM
Turbo-LS's Avatar
its really ore placement of the lines than anything that causes oil to go into the can. the lines off the back of the block are the worst for that. the lines off the vc front dont hardley put any oil in the can and my can was at the height of the block so technically it wcould have been syphoning
Old Mar 30, 2010 | 01:03 AM
Do you have any pics of your set up?
Also, i see that 2 vents of the crankcase is mentionned at the back. Is it not possible even with the turbo in place to vent one from the front?
Old Mar 30, 2010 | 03:35 AM
EddieCRX's Avatar
Hi
It's Eddie off CL forum; I used to use 2 off the back of the block and 2 off the front of the valve cover.
The 2 lines off the back of block would pass oil, under hard acceleration and above 15psi boost, the oil in the engine naturally flows back and as the pressure rises to vent it carries the oil as there is no baffling off these take offs, unless you drain back, the larger the line the better.
I now run just 2 off the front valve cover and they work really well, I have the OE one running into my can and 1 line out to the exhaust to vent.
Even if your engine is new built it’s going to breath, don’t think it won’t, believe me last thing you want is the dip stick popping at 200mph or the cam seals.
Here's an old picture, very dirty back then.
Old Mar 30, 2010 | 04:11 AM
Hi Eddie,
Found me here then!! One question i do have, was your catch tank baffled?
Agree about the new engine breathing, just didnt think before typing!
Old Mar 30, 2010 | 05:00 AM
EddieCRX's Avatar
My catch can vents via the exhaust system, the can its self is just a aluminium water bottle, the line to the exhaust vent is at the top so no baffle is required in the can (for me anyway).
I check the can every now and then, most of the time there is a small amount of mixture in the very bottom, no more than 1/4 inch at worst. Most of the mixture is condensation, as it's constantly venting though the exhaust.
Basically, it’s a 1/4 inch pipe inserted vertically into the down pipe (post) 02, the end inserted has a 45° slash cut facing away from the gas flow, as the exhaust passes it will draw from the catch can (Venturi effect).
Have a search on here for the exhaust evacuation breather method, there was a very long thread with good explanations and pictures.
Another picture of my exhaust set up, you can see the venturi pipe just before the flex joint. And for the record, I don’t use the 02 bung just after the turbo use one further down line.
Old Mar 30, 2010 | 05:05 AM
Thats really interesting stuff, thanks, it looks like a lot of thought has gone in to that.
Old Mar 30, 2010 | 05:36 AM
EddieCRX's Avatar
When you’re trying to cram that lot into a CRX you have no choice other than to think about how it’s all going to fit and work
Old Mar 30, 2010 | 05:39 AM
too true mate, would it be fair to say that the delsols engine bay is a little bigger than the CRX?
Old Mar 30, 2010 | 06:07 AM
EddieCRX's Avatar
Yes, you will have a fair amount more room in front of the engine.
teg19921994
Apr 10, 2018 06:22 PM
slowassBubble
Jul 25, 2012 06:30 PM
blackeg
Apr 5, 2011 04:48 AM
jtm509
May 30, 2010 11:19 AM
lll_fusion_lll
May 20, 2010 05:55 AM
