OH MG, NO Engine Oil??
Old Jul 30, 2002 | 04:34 PM
TurBoXBirD16's Avatar
Default OH MG, NO Engine Oil??
I parked everyday on my driveway, and i know it's not going to be accurate if the driveway is not a flat road
i parked on the road today for few hours, then i went to check my oil, OMG, NOTHING!!! I mean really nothing!! nothing shows on my oil stick !!!
i was like FFFXXXKKK!! I immediately went to change my oil
those drained oil doesn't even have like 1 Q !!
I changed my oil around 4500 KM before, and i have no idea where those oil went !!!
I checked my compression right the way, everything shows up fine
NO white or blue smoke out of my exhaust
What's the problem??
It's a Greddy Turbo Sohc
Thanks !
[Modified by xbird, 6:34 PM 7/30/2002]
Old Jul 30, 2002 | 04:35 PM
Etylorcen's Avatar
Default Re: OH MG, NO Engine Oil?? (xbird)
Probably a leak somewhere. Check your oil return line and the oil feed. Check the seals on the turbo.
Old Jul 30, 2002 | 04:37 PM
Default Re: OH MG, NO Engine Oil?? (Etylorcen)
i checked everything, nothing leaks
if it leaked, it would have showed some kind of oil on the ground on where i park everyday, right??
Old Jul 30, 2002 | 04:58 PM
khang77642's Avatar
yeah same here, I had the same problem too. Unfortunetly the condition was worse. I ended up spinning a rod bearing because it that (long story). I had the same problem. No oil leaks and everything. Change oil not even 2000 miles ago, when problem occured, check oil. No oil !!!I think it was my turbo seal. Probably was eating up the oil. Now I am saving up money for LS motor and upgrading to T3/t4.... hopefully soon.
Old Jul 30, 2002 | 05:07 PM
Default Re: OH MG, NO Engine Oil?? (khang77642)
don't scare me man !!!
What's the problem for me then??
My turbo??
Old Jul 30, 2002 | 05:12 PM
khang77642's Avatar
if you're not leaking oil anywhere, and where you park you car daily and don't see oil spot, it's probably the turbo seal. Not sure, don't know much about turbo. There nothing else I can think of. I check everything, I would never thought myself of doing something stupid like that. *** TIME TO GET A OIL PRESSURE GUAGE...
*the simplest thing can give you a HeaRT aTTack!!!!
had to drink many to that.
Old Jul 30, 2002 | 05:29 PM
but does turbo seal EAT oil THAT fast???
it's like 3 quarts !!!
Old Jul 30, 2002 | 05:40 PM
khang77642's Avatar
naww, I really don't think so. That's why I am so confused !!!. Dunno what to tell you bro. When I am getting ready to take the motor out. I will probably give a Gazillion point inspection for oil leaks. If you find out what wrong, then let me know.
[Modified by khang77642, 8:40 PM 7/30/2002]
Old Jul 30, 2002 | 05:50 PM
we need more ppl to help here !!!!
Old Jul 30, 2002 | 06:03 PM
TheSwift1's Avatar
Are u sure u had oil in there in the first place?
Old Jul 30, 2002 | 06:05 PM
Default Re: OH MG, NO Engine Oil?? (TheSwift1)
haha good try
yes
Old Jul 30, 2002 | 06:06 PM
niedejb's Avatar
How does your coolant look?
Old Jul 30, 2002 | 06:11 PM
Default Re: OH MG, NO Engine Oil?? (niedejb)
normal !
Old Jul 30, 2002 | 07:06 PM
ekb18c's Avatar
The oil has to be going somewhere. If you are saying that there is no smoke coming out of your exhaust then your not burning oil from the turbo. If your turbo seal was bad, you would have tons of smoke. It could your valve steam seals. They may not be sitting properly, so your burnign up all the oil. The oil has to go somewhere, so either its a leak, turbo seal, valve steams seals.
Old Jul 30, 2002 | 08:02 PM
B20LS-T's Avatar
New User
Default Re: OH MG, NO Engine Oil?? (ekb18c)
you could be burning oil, it could be your rings, do a leak down test or have some one do one. also check your oil pan, it could be leaking and burning on your exhaust like mine, hehe
Old Jul 30, 2002 | 08:07 PM
FredoSP's Avatar
this might sound dumb, do you smell anything burning? I mean so oil gets burn via the engine usage .. are you hard on the car??
Old Jul 30, 2002 | 08:11 PM
bruthaboost's Avatar
I'm in the same boat as you. Keep us updated on what you find.
Old Jul 30, 2002 | 09:17 PM
Default Re: OH MG, NO Engine Oil?? (FredoSP)
i don't drive VERY hard on my car, i seldomly boost, it's been hot outside recently
i don't smell anything...
that'svery strange eh??
i just put in new oil, i will check my oil everyday to see what's going on.. hopefully it will be the same level...
but there must be a problem, right?
Old Jul 30, 2002 | 11:27 PM
01geeser's Avatar
New User
i have the same problem too. but it started before my turbo was installed. so i think it must be the valve seals.
Old Jul 31, 2002 | 08:10 AM
glagola1's Avatar
You should take a look at the charge pipe side of the turbo. Take off a pipe or two and if it's covered with oil your turbo seals are gone.
Let me know if you need to rebuild your TD04 because I have a rebuild kit I never used. It's rad and the instructions are color photo.
Old Jul 31, 2002 | 09:07 AM
Default Re: OH MG, NO Engine Oil?? (glagola1)
Ok cool
if i remember correctly, there is no oil in my charge pipes
BUT, there is some oil near the edge of my AIR filter pipe
ver little though
is this the problem??
thanks
stephie1love
Aug 25, 2014 04:01 AM
VI Boost
25
Oct 22, 2008 06:12 PM
SOHC_MShue
Jul 25, 2005 10:36 AM
sushibug
Jun 10, 2002 11:07 AM
PY2KITR1060
May 4, 2002 01:30 PM
