The Official NGK Part Number Thread
I always see threads popping up with people asking for the part numbers for the spark plugs they need. I am only going to list NGK's because they are what I have always used and have never heard one complaint about them.
Iridium - "NGK iridium plugs represent the ultimate evolution of spark plug technology and performance. The iridium center electrode is both stronger and harder than platinum. This allows NGK engineers to design an ultra-fine (0.6mm)center electrode reducing the voltage requirement for spark. This allows for a brighter, stronger spark from your existing ignition system. The ground electrode has a tapered cut at the firing end which reduces quenching for better flame core growth and increased ignitability. The combination of fine wire center electrode and tapered cut ground will increase performance, improve acceleration, and fuel efficiency."
7 - BKR7EIX-11 - 6998
8 - BKR8EIX - 2668
9 - BKR9EIX - 2669
V-Power Racing - "NGK's unique V-Power racing plug provides racing performance at an economical price. Designed to direct the spark to the edge of the electrode where it develops more rapidly, this increases ignitability allowing the engine to burn air/fuel ratios that would otherwise be too lean. Traditional ground electrode. In addition the NGK V-Power racing plugs are constructed with a copper core and triple interior seal."
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
10 - R5671A-10 - 5820
Traditional - "NGK traditional plugs are constructed for longer life and optimum performance. Corrugated ribs prevent flashover. NGK uses only the purest alumina silicate in its ceramic insulator which give all NGK plugs greater strength and better heat transfer. Copper cored and triple sealed to further aid in heat removal and prevent interior leakage."
6 - BKR6E-11 - 2756
7 - BKR7E-11 - 1283
Modified by dunkd at 10:19 PM 7/5/2006
8 - BKR8EIX - 2668
9 - BKR9EIX - 2669
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
6 - BKR6E-11 - 2756
7 - BKR7E-11 - 1283
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
This is what I use
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
This is what I use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I use BKR7E #6097
I don't like Iridiums.</TD></TR></TABLE>
yea this thread isnt complete without the 6097's
some do some dont, but this plug (2668) was suggested to me by john from NGK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
some do some dont, but this plug (2668) was suggested to me by john from NGK.</TD></TR></TABLE>
I know some people swear by iridium plugs. I just never had any real good luck with them. I like the simple basic designs, they work tried and true.
You'll want to get those zfr's out of there. If you call NGK they will tell you those plugs will fall apart in our engines, they have proof. They will tell you to run BKR7E11's.
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
i use R5671A-10
7 - R5671A-7 - 4091
8 - R5671A-8 - 4554
9 - R5671A-9 - 5238
i use R5671A-10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .m a c a »</TD></TR><TR><TD CLASS="quote">yea this thread isnt complete without the 6097's
I am pretty sure the 6097's are the same as the 1283's, except the 1283's are pregapped to .044. They are both also the same price.
I also added a couple more part #'s
</TD></TR></TABLE>I am pretty sure the 6097's are the same as the 1283's, except the 1283's are pregapped to .044. They are both also the same price.
just curious, has anyone ever heard of using the oem plugs from a 91 crx si? i was reading a thread on here(a while ago) and could of sworn someone said something about them being great for low boost apps ........
infamouskillas
Apr 19, 2008 07:14 PM
