oem oversized bearings discontinued!!!!!
I needed black bearings from the honda color code chart to get .0015in on my rod bearings. My local dealership says there discontinued and only the stand sizes are availble. What do i do now? the aftermarket bearings 0.10 over are way to big for my needs and the std size is just to loose! what are my options?
Get the crank machined down to fit the oversize aftermarket bearing. Alternatively, you can knock down an oversized bearing with scotchbrite as well. If your using non race bearings there is a coating on them that can be knocked off pretty quick. That's commonly removed when building race duty engines for road racing, etc. Lots of options.
IN VTEC
03-18-2006 08:40 PM
