odyssey batteries
Old Aug 18, 2008 | 11:32 AM
90Rexx's Avatar
Default odyssey batteries
so does anyone have one of those mini odyssey batteries in their car? i need to get one because battery relocation is not an option and theres no room in my engine bay. so i was looking at the pc680 odyssey battery. anyone use one of these before? its to crank a b18a. says it only has 220 cca and 300 ca? seems low :-\
Old Aug 18, 2008 | 11:45 AM
tony1's Avatar
Default Re: odyssey batteries (90Rexx)
It'll start the engine fine, just don't leave the key on with anything drawing from it. From my experience, those batteries are always a problem. It's not a matter of if, only when.
Old Aug 18, 2008 | 12:28 PM
93egsir's Avatar
I have a 11.7:1 ls vtec and it starts everytime no problem. I'm running the pc680 and have 2 amps one sub so on so on. never had a concern and like the battery size alot stood it on end and post face the engine. Built my own tie down.
Old Aug 18, 2008 | 12:50 PM
ESP801's Avatar
i think they might be just fine but my question is can they power an amp and sub(s)?
Old Aug 18, 2008 | 12:58 PM
TimKennard's Avatar
i have a pc680. i always charge before race. never had a problem in 20 something weekends. not sure i would run one in a DD. they drain fast if the alternator isn't charging. guess it depends on how much reserve you need and what its for.
Old Aug 19, 2008 | 03:20 AM
90Rexx's Avatar
thanks for the input everyone. this will be for a ls turbo weekend warrior. i think im gonna order one today. seems to fit the bill fine, comes with a 2 yr warrenty so im not too worried about the problems. now to start construction of my own battery tie, cuz i aint spendin 60 bucks on theirs lol.
Old Aug 19, 2008 | 10:59 AM
Spunkster's Avatar
Use the Dekka ETX20L
good battery about 15 lbs
Old Aug 19, 2008 | 01:54 PM
UK Accord's Avatar
I'm using a Odyssey PC545 and it works just fine.
Old Aug 19, 2008 | 03:09 PM
DaveF's Avatar
Default Re: (UK Accord)
those little batteries are garbage ! i had one in my racecar last season. (it was brand new at the time) on the dyno we had to keep a charger on it, so it would start. at the MIR BOTI race, i had to crank the car a bunch because of a fuel system situation, needless to say, i didnt get the car started
we also ran one of them little batteries on the other racecar, the terminal came loose in the battery housing or whatever its refered to as.. but anyhow. the car had problems at the launch the terminal would come loose, the car would loose all power. it happend a few times before, the battery just quit.
i have since switched to a Rock racing battery, and did not have any similar problems this season.
the old battery
the new battery
Old Aug 19, 2008 | 06:45 PM
Crx Jimmy's Avatar
Default Re: (DaveF)
Must have been a problem with the battery , I have had mine for years and it has always worked fine. I have seen some 7 years old and still going. They are better than any stock battery I have used
Old Aug 19, 2008 | 06:53 PM
mrbsponge's Avatar
doesnt that Rock Racing battery weigh like over 40 lbs?
Im trying to choose a battery right now and to be honest its a tough call
Old Aug 19, 2008 | 08:18 PM
DaveF's Avatar
Default Re: (mrbsponge)
Rock 1236
12 Volt Battery
Heavy Duty Deep Cycle
Size: 5.25" wide x 7.625" long x 6.875" tall
700 amps CCA @ 20 second rate
36 Reserve Capacity Minutes
Peak Discharge Amps: 1200 @ 15 seconds
Weight: 24 lbs.
Old Aug 19, 2008 | 08:20 PM
DaveF's Avatar
Default Re: (DaveF)
here is more info on Rock Racing Batteries
http://www.rockracingbattery.com/specs.php
Old Aug 19, 2008 | 09:44 PM
Drew Peacock's Avatar
I have the odyssey seems like a good battery. Don't let them get real run down to often, on a daily driver with a decent alternator I can't see this happening.
i am interested in how long it will last not being a daily, my car used to chew through similar sized batteries they were much cheaper however.
Old Aug 20, 2008 | 12:22 AM
CRXdan's Avatar
Default Re: (Drew Peacock)
im runnign one, no problems yet. although it didnt start my car one day, maybe i left the radio on while cleaning it or something. They dont like alot of draw (ie, cant blast your radio with wipers/hibeams/heater and operate the sunroof) but for a weekend car or even a daily in the summer i dont see it being a problem.
Old Aug 20, 2008 | 04:25 AM
90Rexx's Avatar
thanks for the input davef and very nice car, unfortunately size is the biggest issue here which is why odyssey seems like my solution. weight not so much, just size.
duyfash0
Audio / Security / Video
Mar 24, 2008 03:10 PM
Midori Green
Nov 30, 2007 09:57 PM
CRXEE8
Apr 20, 2007 11:26 AM
Rex89
Oct 21, 2006 05:49 AM
smash fascism
Dec 3, 2005 07:58 PM
