occational boost= Check engine light and high idle
I have a turbo which was installed last week. My question is this. Sometimes when I boost up to about 4-9 psi my check engine light comes on. Before I do this my car idles at about 500 rpm. After it's about 1100rpm. I mean I can drive it like it wasn't turbo and the light won't come on. It happens everytime I drive it and put some serious spool on the turbo. Any clue what this could be? I was thinking something along the lines of the MAP sensor reading too much air. Or there oxygen sensor is screwed. I have not clue. Please advise. Thanks
Re: occational boost= Check engine light and high idle (evosol)
um well it's very sufisticated. I am running a piggy back managment system connected to the stand alone AEM. Acutally I was just bullshitting. I don't have any fuel managment. They ( the garage that hooked the turbo up) said they remapped the fuel. Whatever that means. Let me know what you think now. The light even comes on a 4 psi sometimes.
Re: occational boost= Check engine light and high idle (Integra GSR 95)
You're going to have to pull the code before you can even guess on what's happening. A blind guess might be something like rich/lean condition, or maybe map related.
Re: occational boost= Check engine light and high idle (dennis)
sounds like you need a missing link....
if you don't have engine management at all, there's no way to change the fuel maps. hope you have an fmu at least
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra GSR 95 »</TD></TR><TR><TD CLASS="quote">um well it's very sufisticated. I am running a piggy back managment system connected to the stand alone AEM. Acutally I was just bullshitting. I don't have any fuel managment. They ( the garage that hooked the turbo up) said they remapped the fuel. Whatever that means. Let me know what you think now. The light even comes on a 4 psi sometimes. </TD></TR></TABLE>
tell me you're kidding
If your Map sensor reads 7.5PSI or over it will throw a code and pulse the injectors. This will make the idle higher. You need bigger injectors and a tune or at least an FMU for now.
Re: occational boost= Check engine light and high idle (TurboTagTeam)
yeah you need a missing link...but what codes are you throwing, I wouldn't blind guess on something like that. But yeah I would think something air/fuel related too. I get codes thrown all the time but its cause of the air/fuel mix that I'm running according to my OBD scanner.
wambus
08-15-2003 02:19 PM
wambus
08-12-2003 07:38 AM
