OBX LSD Users Only
Old Sep 2, 2006 | 07:12 PM
  #76
19sec beast's Avatar
Default Re: (StreetEG)
I'm also wondering that. I've been searching the archives lately, but have come up with nothing. I thought there was a detailed walk thru with pics on torquing and tightening the OBX LSD.
Old Sep 2, 2006 | 07:37 PM
  #77
OBRJosh's Avatar
[QUOTE=StreetEG]can someone give a full explanation of how they rebuild their obx before they put it in?
Where do you get the torque specs from?
What fluid do they use?
Any bolts need replacing?
Loctite?
Yea i took out the allen bolts, Brake cleaned them, Put red loctite and put them as tight as i could by hand without stripping the allen bolts, and i use straight 30weight oil nothing special, ive used MTL but i had a leaky axle seal so i fixed that and went with regular straight 30 and i dont notice any differnece
Old Sep 3, 2006 | 04:06 PM
  #78
OBRJosh's Avatar
Default Re: (rota92)
nah you wont have any problems Ibeat the **** out of mine for 10,000 miles and still climing ,and shes still mint I snaped a axle inhalf in the middle of the shaft so i know the obx is strong
Old Sep 4, 2006 | 07:30 AM
  #79
kamAccord's Avatar
Default Re: OBX LSD Users Only (kamAccord)
Any H22 experinces?
Old Sep 7, 2006 | 08:52 AM
  #80
kamAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamAccord &raquo;</TD></TR><TR><TD CLASS="quote">Those of you that use the OBX LSD please reply to the questions as follows:
1. Are you satisfied with the performance?
2. If you experienced problems with your OBX LSD, was OBX or the seller willing to honor the warranty of the product and replace or repair the product?
3. If you were in the market for another LSD would you purchase the OBX LSD or purchase another brand LSD such as Quaife?
Your sincere response is greatly appreciated. Thanks in advance. </TD></TR></TABLE>
Any new updates?
Old Sep 7, 2006 | 10:53 AM
  #81
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamAccord &raquo;</TD></TR><TR><TD CLASS="quote">Any H22 experinces?</TD></TR></TABLE>
get one and if all goes well then i will get one on my lude
Old Sep 7, 2006 | 11:02 AM
  #82
b16hybridsol's Avatar
Default Re: OBX LSD Users Only (Lude_Nation)
i just did one for a buddies car, haven't ran it yet but assembly wise i can share some.
First off the bolts weren't torqued, as usual. upon dissassembly i found a grease like coating on the internals that had the consistansy of valve lapping compound. the washers were placed like )())((. And it made some loose noises when it was shaken.
So i reassembled it per other peoples specs on here with some assembly lube also. And it seemed to tighten everything up, loctite on the allen heads and ring gears bolts, washers like this ()()() and i guess we'll see what happens in the next couple weeks when the car comes out
Old Mar 8, 2007 | 05:04 AM
  #83
eblucarbonem1's Avatar
Default Re: OBX LSD Users Only (b16hybridsol)
good info, how are these things still holding up? getting one soon
Old Mar 8, 2007 | 06:05 AM
  #84
b18sihatch's Avatar
Default Re: OBX LSD Users Only (eblucarbonem1)
i got one in my ls transmission i plan on using for my high high whp application, did all the normal ''recorrecting'' if you will, and dont feel i have anything to worry about with it.
kaylins2k
Honda S2000
Jul 14, 2005 07:45 PM
.Ryan
12
Apr 3, 2005 06:57 PM
riceburners1
13
Jun 26, 2004 08:52 AM
mr devious illusions
Mar 16, 2004 11:27 AM
Bulldogg83
Oct 27, 2003 11:04 PM
