OBX LSD Users Only
Old Aug 25, 2006 | 01:21 PM
  #26
b18bturbo's Avatar
Default Re: (kamAccord)
h22 never had the issue. nor did the rsx
Old Aug 25, 2006 | 01:37 PM
  #27
mike93eh2's Avatar
d series problem was corrected like i already said... unless you order and get one that has been sitting on the shelf for a long time.
Old Aug 25, 2006 | 02:08 PM
  #28
b18bturbo's Avatar
Default Re: (mike93eh2)
yup what he said part number for d model is lsd 9200
Old Aug 25, 2006 | 02:25 PM
  #29
kamAccord's Avatar
Default Re: (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">h22 never had the issue. nor did the rsx</TD></TR></TABLE>
Thanks.
Old Aug 26, 2006 | 06:26 PM
  #30
kamAccord's Avatar
Default Re: OBX LSD Users Only (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">
just the pass. axle issue
3. If you were in the market for another LSD would you purchase the OBX LSD or purchase another brand LSD such as Quaife?
i think i would go with a quaife and use the obx as a back up.
Why would you go with a Quaife if you were in the market for another LSD?
Old Aug 26, 2006 | 06:41 PM
  #31
86si's Avatar
Default Re: OBX LSD Users Only (kamAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you go with a Quaife if you were in the market for another LSD?</TD></TR></TABLE>
i just don't like the customer service at OBX. (my experience)
Old Aug 26, 2006 | 09:31 PM
  #32
fast2camciv's Avatar
ive got one in my 405whp d-series and i love it...i have had ZERO issues with it including the axle thing...it helped a ton in cornering and it was the single biggest thing i did in order to get traction from my turbo setup.
i would buy one again i loved it! got mine from sparktec as well...cheapest place to get it from lol
Old Aug 26, 2006 | 10:50 PM
  #33
sohc_turd's Avatar
Default Re: (fast2camciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv &raquo;</TD></TR><TR><TD CLASS="quote">ive got one in my 405whp d-series and i love it...i have had ZERO issues with it including the axle thing...it helped a ton in cornering and it was the single biggest thing i did in order to get traction from my turbo setup.
i would buy one again i loved it! got mine from sparktec as well...cheapest place to get it from lol</TD></TR></TABLE>
I'm also running one too. ^^ homeboy sums it up.
Old Aug 27, 2006 | 01:08 AM
  #34
raene's Avatar
1. Yup. 12.77 on street tires at street pressure says it all. It just hooks so much better.
2. No problems so far except it's noisy, but that's probably because I didn't shim it or change the bearings. Tranny needs a rebuild anyway...
3. I couldn't afford a Quaife regardless.
Old Aug 27, 2006 | 02:22 AM
  #35
HYBRID_H@TCH's Avatar
Default Re: OBX LSD Users Only (raene)
I run one and love the thing..1.5 sixty foots and over 600,700,800 whp thrown at it over 3 years!! I finaly broke a axle which hurt the lsd a little but the new one under warranty will be here soon...even if they dont cover it..I will still buy another..
Old Aug 27, 2006 | 05:33 AM
  #36
kamAccord's Avatar
i just don't like the customer service at OBX. (my experience)</TD></TR></TABLE>
That's definitely reason enough!
Old Aug 27, 2006 | 05:43 AM
  #37
non-VTEC's Avatar
me too.
https://honda-tech.com/zerothread/1381146
Old Aug 27, 2006 | 07:36 AM
  #38
RaNMaN's Avatar
Default Re: OBX LSD Users Only (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">I have it in my ls tranny. Works great. No problems for almost two years now.</TD></TR></TABLE>
X 2
Old Aug 27, 2006 | 07:44 AM
  #39
DfwBB6's Avatar
very nice information guys im thinking of getting one for my h22 and to think i almost got a quaife $995....ouch! anymore results from other people?
Modified by Lude_Nation at 4:20 PM 8/27/2006
Old Aug 28, 2006 | 06:09 AM
  #40
Foowee's Avatar
Default Re: (Lude_Nation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude_Nation &raquo;</TD></TR><TR><TD CLASS="quote">very nice information guys im thinking of getting one for my h22 and to think i almost got a quaife $995....ouch! anymore results from other people?
Modified by Lude_Nation at 4:20 PM 8/27/2006</TD></TR></TABLE>
buy an obx and use the leftover cash to buy axels...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Did you remove the stock shim? If not does your case leak fluid?
Old Aug 29, 2006 | 03:19 PM
  #41
kamAccord's Avatar
Camp 1320 has them for $375 shipped! I need more info though.
Old Aug 29, 2006 | 04:02 PM
  #42
tegasaurus's Avatar
for those of you with positive results from OBX, are you just using the lsd right out of the box installed, or are you modifying them in any way?
Old Aug 29, 2006 | 04:12 PM
  #43
OBRJosh's Avatar
Default Re: (tegasaurus)
i had to shave the inside on the axle side casue the axle used to get stuck HAHA fixed that problem and shes holding fine, fresh honda bearings good to go so far
Old Aug 29, 2006 | 04:14 PM
  #44
OBRJosh's Avatar
Default Re: (OBRJosh)
Also i took the bolts out, lock tighted them and torqed them down
Old Aug 29, 2006 | 04:34 PM
  #45
Cimburke23's Avatar
from me for this lsd, didnt really improve my 60 or 1/4 time much, but i dont hav eto worry about shattering a spider gear anymore now. i took mine straight out the box, had a speedo gear and bearings pressed on it and threw it in the tranny. no axle problems with this one, but i will be pulling it apart over the winter just to check everything in it. when i put it in it was a rush situation. i have owned a quaife and they didnt cover a problem under warranty so i will never buy another one again. obx all the way, same product and 1/2 the price
Old Aug 29, 2006 | 05:02 PM
  #46
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">for those of you with positive results from OBX, are you just using the lsd right out of the box installed, or are you modifying them in any way? </TD></TR></TABLE>
just make sure you take it apart and retorque everything and you will be fine..
platinum
Old Aug 29, 2006 | 06:11 PM
  #47
19sec beast's Avatar
Default Re: (platinum00)
Very good and informative thread.
I guess I'll see how it handles 630whp/411ft lbs of torque.
Old Aug 29, 2006 | 08:46 PM
  #48
jdmdc529's Avatar
I am very curious how the LSD will handle a 600+ Hp car. Please let me know.
Old Aug 30, 2006 | 04:49 AM
  #49
b18bturbo's Avatar
Default Re: (jdmdc529)
i think there is only limted few that have tried in 600hp + i think hybrd99 is the only one that i know and his is working great for about 2 years now
Old Aug 30, 2006 | 08:43 AM
  #50
Mr.OB*GYN_Rhett's Avatar
word on the street: Quafie and OBX, same unit
