OBX LSD?
Old Nov 21, 2004 | 11:41 AM
  #476
Boosted Chemist's Avatar
Default Re: (Maxime)
any word on the gsr/itr lsd?
Old Nov 21, 2004 | 11:43 AM
  #477
Soon_2b_evil's Avatar
Default Re: (Boosted Chemist)
im waiting on EARL.
Old Nov 21, 2004 | 11:45 AM
  #478
ATS*Mark's Avatar
OG triple OG
Default Re: (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">im waiting on EARL. </TD></TR></TABLE>
Old Nov 21, 2004 | 12:35 PM
  #479
plusONE jboy's Avatar
as we all are
Old Nov 21, 2004 | 09:35 PM
  #480
Simple SOHC's Avatar
I'll be ordering one maybe next week...made $300 commission this week...so I should have enough. Since the other guy was mainly a drag car with the 600whp turbo/nitrous setup...I'll let you know how it holds up to semi-regular basis Mtn abuse. It will be on a SOHC setup with about 180-200whp.
Old Nov 21, 2004 | 10:56 PM
  #481
Nutzurchin's Avatar
Default Re: (H23 EG Hybrid)
if u need obx lsd i can get them for u, just im me, brand new let me know which one u need
Modified by nutzurchin at 8:06 PM 11/22/2004
Old Nov 22, 2004 | 05:56 PM
  #482
earl's Avatar
Default Re: (nutzurchin)
I will post my review of the OBX vs. Quaife tonight in a seperate thread.
Old Nov 22, 2004 | 06:00 PM
  #483
99lsvtecauto's Avatar
Default Re: (earl)
finally thank u
Old Nov 22, 2004 | 06:28 PM
  #484
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I will post my review of the OBX vs. Quaife tonight in a seperate thread.</TD></TR></TABLE>
sweet! i'll be awaiting the thread.
Old Nov 22, 2004 | 06:31 PM
  #485
Default Re: (earl)
Oh YEAH!
Old Nov 22, 2004 | 06:36 PM
  #486
adictionbass's Avatar
Oh boy waiting......
Old Nov 22, 2004 | 07:36 PM
  #487
earls review. https://honda-tech.com/zerothread?id=1064239
Old Nov 23, 2004 | 12:03 PM
  #488
Default Re: (j boy)
excellent review i would like some 1 with a gsr 2 try it in there car
Old Nov 24, 2004 | 06:41 AM
  #489
Maxime's Avatar
Default Re: (99lsvtecauto)
<U>Okay I need help FAST!!!!</U>
We are having clearance issues<U></U> while installing the OBX LSD in my SI tranny.
The guy told me he couldnt find a shime small enough to have enough clearance.
PLS PLS help me.
My car has been out of busniess for almost a month. I can't afford to not drive it for much longer. This is being a real pain in the *** to get a ride to work everyday.
Old Nov 24, 2004 | 07:35 AM
  #490
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxime &raquo;</TD></TR><TR><TD CLASS="quote">
Pick yourself up a set of bearings from a 90-91 integra tranny. They are the same inside and outside diameter, however they are slightly thinner. By a few millimeters. You will then have to get larger shims.
Old Nov 24, 2004 | 07:38 AM
  #491
rioninja's Avatar
Default Re: (rioninja)
I believe they are 1.5mm thinner than the newer bearings.
Old Nov 24, 2004 | 11:20 AM
  #492
obx dealer says that u can put si lsd into gsr tranny by using different bearings , switching the ring gear has any one done this or tried this
Old Nov 24, 2004 | 12:13 PM
  #493
Maxime's Avatar
Where am I gonna find bearings for a 90-91 integra tranny? Do they still sell those at the dealer?
Somebody suggested that I only put a shim on one side of the LSD.
Old Nov 24, 2004 | 01:26 PM
  #494
call barango acura ask for lenny if it can be got lenny can get it for u
Old Nov 24, 2004 | 01:31 PM
  #495
Slick GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto &raquo;</TD></TR><TR><TD CLASS="quote">obx dealer says that u can put si lsd into gsr tranny by using different bearings , switching the ring gear has any one done this or tried this </TD></TR></TABLE>
bump to this!
Old Nov 24, 2004 | 01:59 PM
  #496
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxime &raquo;</TD></TR><TR><TD CLASS="quote">Where am I gonna find bearings for a 90-91 integra tranny? Do they still sell those at the dealer?
Somebody suggested that I only put a shim on one side of the LSD.</TD></TR></TABLE>
Yeah, you can buy them at the dealer.
And yeah, you dont necessarily need a shim on each side. As long as its to spec.
Old Nov 25, 2004 | 05:41 PM
  #497
Mista Bone's Avatar
D Tranny Guru
FYI LS and D series EX use the same diff bearings.
Simple eh?
$34 each.
Also ANYTIME a diff is changed, you MUST check shim clearance!!!!!
Old Nov 25, 2004 | 07:04 PM
  #498
Sobe_Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto &raquo;</TD></TR><TR><TD CLASS="quote">call barango acura ask for lenny if it can be got lenny can get it for u </TD></TR></TABLE>
you mean Len?? haha he's gonna laugh when i tell him about this!
Old Nov 25, 2004 | 08:55 PM
  #499
RMS's Avatar
RMS
double check the shim on one side idea...loading the bearing against the aluminum case doesn't seem like a good idea.
Old Nov 30, 2004 | 10:51 AM
  #500
platinum00's Avatar
Default Re: (RMS)
are these the correct part numbers and items i need to install in a y8 tranny
41312-PL3-B00 speedo gear
91005-PS1-003 Diff bearing, need 2
91002-PSO-003 ISB bearing
91216-PL3-005 ISB seal
23927-PL3-000 thrust washer
23928-PL3-000 thrust washer
platinum.
