OBDII to OBDI question
Old Jun 22, 2005 | 02:57 AM
kraig8's Avatar
Default OBDII to OBDI question
i have a question about switching from a obd2 ecu to obd1. i would like to know how difficult is it. is it just a harness conversion or a whole new wiring harness. im buying a hondata s200 so i have to switch over. so any information would greatly be apriciated
thanks,
craig
Old Jun 22, 2005 | 04:55 AM
crx34's Avatar
I know you will have to change the dizzy, new wire clips for injectors, & hareness conversion. Your car is 01 teg? Thats all I am aware of.
Old Jun 22, 2005 | 04:58 AM
ginoboy1978's Avatar
Default Re: OBDII to OBDI question (kraig8)
Hey bud....its easy.
Get a OBDII to OBDI conversion harness.
Unplug your obd2 ecu and take it out. Plug the wires into the conversion harness, then get the wires from the conversion harness and plug them into the obd1 ecu. Its just plug and play.
DAN
Old Jun 22, 2005 | 04:59 AM
Tactic$'s Avatar
Default Re: OBDII to OBDI question (ginoboy1978)
You DO NOT need a new dizzy
Old Jun 22, 2005 | 05:01 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: OBDII to OBDI question (Tactic$)
Get a harness from Blown90hatch and you'll be set.
art
Old Jun 22, 2005 | 06:31 AM
xenocron's Avatar
Default Re: OBDII to OBDI question (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Get a harness from Blown90hatch and you'll be set.
art</TD></TR></TABLE>
What he said
Old Jun 22, 2005 | 11:03 AM
bnut510's Avatar
easy as hell, plug and play basically. i just recently swapped mine from a obdII to obdI on my 99 si.
Old Jun 22, 2005 | 12:04 PM
s2kdre's Avatar
Default Re: OBDII to OBDI question (bnut510)
theres no need to swap out the whole enigine harness
Old Jun 22, 2005 | 12:33 PM
bottlefed13's Avatar
Default Re: OBDII to OBDI question (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question about switching from a obd2 ecu to obd1. i would like to know how difficult is it. is it just a harness conversion or a whole new wiring harness. im buying a hondata s200 so i have to switch over. so any information would greatly be apriciated
thanks,
craig</TD></TR></TABLE>
all you have to do is:
1) buy the OBDIIB to OBDI conversion harness.
2) get the OBDI ecu chipped to a DOHC VTEC program.
3) plug it in and let the car idle to adjust itself.
thats's it.
Old Jun 22, 2005 | 02:37 PM
Boofster's Avatar
Default Re: OBDII to OBDI question (bottlefed13)
bottlefed13 is correct. I did this on my car.
Make sure to get the OBD2B to OBD1 harness though because they changed it on 00 and 01 cars. Evasive Motorports sells for $60 bux.
I recommend a OBD1 P72 or P28 ECU and make sure to get a base map on the Hondata chip because it won't even start otherwise.
You will likely want to get new injectors and clips for da boost.
Also, keep your original ECU and injectors to swap back when it's time to pass emissions.
Modified by Boofster at 4:01 PM 6/23/2005
99JdmDc2
Aug 16, 2007 07:43 AM
Touge Tuning
May 6, 2005 07:53 PM
quaker
Feb 20, 2004 12:24 PM
Malachi_
14
Sep 25, 2003 04:12 PM
