not making power and dont know why???
Old 02-12-2006, 01:13 PM
ecks_fourttwo's Avatar
Default not making power and dont know why???
my all motor setup dyno'd at 169 whp and 126 tq. now i put a turbo kit on and to my surprise i dyno'd at 184 whp and 146 tq. that just doesnt sound right to me, so i swaped out my stage 1 cams for some gsr cams and prayed for a improvement. well needless to say there was no improvement. i lost top end power...
i found a couple of leaks...fixed them and still no top end power... i keep losing boost through out the top end....7..6...5..
i had better top end with the stage 1's....but with the gsr's i gained in my mid range...
anyone have any ideas on where to looking for problems...? could it just be the turbo itself that has gone bad?
i running a stock b18b block and b16 head with dual valve springs/retainers, adjustable cam gears, chipped p28, and a greddy turbo kit.
please help...thanks
Old 02-12-2006, 01:44 PM
bump
Old 02-12-2006, 02:00 PM
delslo93's Avatar
Default Re: (ecks_fourttwo)
how much boost are you running? I think that kit is something like 5.5 psi? Do you have a boost gauge to see if your getting the boost into the intake manifold? Check IC piping connections. Good luck
Old 02-12-2006, 02:05 PM
93NTEGLS's Avatar
i would also get it tuned. cuz you could throw a kit on there and prolly gain about 50-75 hp, but if you get it tuned those numbers could almost triple. not to mention it being a lot more reliable than before. just my .02
Old 02-12-2006, 08:05 PM
willie_su2166's Avatar
Default Re: not making power and dont know why??? (ecks_fourttwo)
I had the same problem on my boosted b18c, the problem was bad wire connection because vtec was not working properly.
Old 02-13-2006, 03:26 PM
Default Re: not making power and dont know why??? (willie_su2166)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem on my boosted b18c, the problem was bad wire connection because vtec was not working properly.</TD></TR></TABLE>
where did you find the wire problem...just asking so that i can know where to start looking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93NTEGLS &raquo;</TD></TR><TR><TD CLASS="quote">i would also get it tuned. cuz you could throw a kit on there and prolly gain about 50-75 hp, but if you get it tuned those numbers could almost triple. not to mention it being a lot more reliable than before. just my .02</TD></TR></TABLE>
i did get it tuned...at first we though it might be the stage 1 cams that where overlapping too much and letting too much boost out... so we swapped out with gsr cams, and it still made no difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">how much boost are you running? I think that kit is something like 5.5 psi? Do you have a boost gauge to see if your getting the boost into the intake manifold? Check IC piping connections. Good luck</TD></TR></TABLE>
im running 7 psi right now...
Old 02-13-2006, 03:31 PM
delslo93's Avatar
so you're running 7 psi so thats what your boost gauge says? Or are you just going off of what the stock wastegate spring is?
Old 02-14-2006, 10:14 AM
Default Re: not making power and dont know why??? (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">so you're running 7 psi so thats what your boost gauge says? Or are you just going off of what the stock wastegate spring is?</TD></TR></TABLE>
thats what the gauge says... it goes to 7 and drops slowly from there.
Old 02-14-2006, 02:31 PM
delslo93's Avatar
we'll it sounds like you have a boost leak then my friend. Check possible sources for pressure losses.
Old 02-14-2006, 08:33 PM
could it be that the bolt on the waste gate is loose?
Old 02-21-2006, 09:23 AM
problem solved...
Old 02-21-2006, 09:43 AM
no2unenolife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecks_fourttwo &raquo;</TD></TR><TR><TD CLASS="quote">problem solved...</TD></TR></TABLE>
wat was the problem?
Old 02-21-2006, 12:18 PM
Default Re: (no2unenolife)
it was one of those nasty leaks... it was coming from the weld on the blow off valve... and another on the charge pipe... after getting rid of those leaks i made another 26 whp and 31 lbs. tq.!
crazyassbill
11-19-2011 06:37 AM
KdF
05-23-2010 05:14 PM
ghostofnyc
12-26-2007 12:49 PM
JSiRTO
10-09-2006 04:22 PM
Quick Reply: not making power and dont know why???
