not boosting any more....
Old Oct 12, 2002 | 06:15 PM
Mugen Dom's Avatar
Default not boosting any more....
my friends 99 si with drag3 kit on it went into limp mode when the o2 was covered in black carbon deposits from running so rich...It was consistantly runnnig 6 psi and after we took out the o2 today cleaned it up and started it up again with new plugs also its not boostingabove 1 or 2 psi any ideas we cant find a leak anywhere and all vacume lines are connected BOV is working properly...im stumped
Old Oct 12, 2002 | 07:05 PM
FredoSP's Avatar
Default Re: not boosting any more.... (JdMB16Ahatch)
hmm .. were the plugs gapped properly? Maybe you should just buy a new O2 Sensor? Did you reset the ECU?
Old Oct 13, 2002 | 07:49 AM
Mugen Dom's Avatar
Default Re: not boosting any more.... (FredoSP)
uhhh plugs are NGK v power only ones they had gapped to .044 have some denso iridiums dont know what to gap em at so didnt put em in.... anything wrong with .044??? we reset the ecu the O2 was fine it was still working code 61 slow to respond if u were covered in carbon ud be slow to respond also any help s apreciated
Old Oct 13, 2002 | 08:37 AM
Jared's Avatar
44 is a little large for a turbo car with stock ignition. try .030
Old Oct 13, 2002 | 08:54 AM
FredoSP's Avatar
My NGK's were gapped at .032 .. try that, hopefully it should fix the problem.
Old Oct 13, 2002 | 06:45 PM
Mugen Dom's Avatar
i duno about it being to wide in my integra manual teh b17 gap is .039-.043 so i dont think its gap is doin it
Old Oct 13, 2002 | 06:46 PM
sutrusu's Avatar
run ngk bkr-7e plugs at .30
Old Oct 13, 2002 | 06:52 PM
Mugen Dom's Avatar
Default Re: not boosting any more.... (sutrusu)
ok ill do that for him hopefully they stock the plug and hope it fixes it my friend is upset that its not boosting
Old Oct 13, 2002 | 08:31 PM
BoostedED9's Avatar
what should ngk 3330 (bcpr7es) be gapped to with a msd6btm??????
Old Oct 13, 2002 | 09:18 PM
TurbothisLS's Avatar
hey the bker7's work for an LS?
thanks
Old Oct 14, 2002 | 08:40 AM
ladysman's Avatar
Default Re: not boosting any more.... (ED9Hybrid)
I would be interested in this as well. Bump.
1993eghatch
17
Jan 21, 2011 09:22 PM
98IntegraLSNonVtec
Aug 4, 2006 09:18 PM
petergriffen
Jun 8, 2005 11:17 AM
mRek9R
May 9, 2004 10:38 PM
Formula 1
May 15, 2003 11:22 AM
