Chipped ECU
Old Oct 13, 2002 | 06:57 PM
Thrillhouse's Avatar
Default Chipped ECU
Can you chip your ecu if you have a jrsc??? Do they interfere with each other? Does the chip that increases redline to 8200 rpm put a lot more wear and tear on your engine? Im sorry if these are dumb questions i searched but did not find anything. Thx.
Old Oct 13, 2002 | 07:24 PM
b18turbocivic's Avatar
Default Re: Chipped ECU (Thrillhouse)
A chip to increase your redline is not going to help unless the head is built to handle it and by looking at your sig it's not, so dont do it. If this chip is designed for NA setups then it's not going to work well with your JSRC since it advances timing and increases your chances of detonation.
Old Oct 13, 2002 | 09:44 PM
Default Re: Chipped ECU (b18turbocivic)
Good info thx you helped out a newbie and made him a little less stupid
Old Oct 14, 2002 | 08:57 AM
ATgrills.com's Avatar
Chipped ECU's and FI is bad new,, with my chipped PYR p75 ecu I detonated like crazy because the of the advanced map timming! so I had to go back to stock!
Tyler
djkina
Engine Management and Tuning
Sep 19, 2018 05:36 AM
98_ssbp
May 29, 2012 12:44 AM
ryanevansoh
Jan 13, 2009 08:50 PM
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
