normal #'s?
Old Aug 11, 2005 | 12:32 AM
fanta!'s Avatar
Default normal #'s?
h22
idle- 20-25 vac AND 20-25 oil pressure (autometer gauges for boost and oil pressure)
what should vac be at or does it not really matter? sometimes its more than others, its ussually right at 20
Old Aug 11, 2005 | 02:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: normal #'s? (fanta!)
your vac is fine vac should be between 18-25 varies from motor to motor..... your oil pressure is that warm at idle right? if so its good and normal should be about 70-80psi...
Old Aug 11, 2005 | 09:43 AM
fanta!'s Avatar
Default Re: normal #'s? (Snoflake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake &raquo;</TD></TR><TR><TD CLASS="quote">your vac is fine vac should be between 18-25 varies from motor to motor..... your oil pressure is that warm at idle right? if so its good and normal should be about 70-80psi...</TD></TR></TABLE>
yeah the oil pressure when its at 20-25 is at warm idle. what do you mean 70-80psi?
Old Aug 11, 2005 | 09:54 AM
DaveF's Avatar
your oil pressure is fine. when your up in the rpms a bit your oil pressure should be around 75.
Old Aug 11, 2005 | 11:36 AM
LuderCriS's Avatar
Default Re: normal #'s? (Dturbocivic)
what kinda oil are you using guys? im using 5w-30
Old Aug 11, 2005 | 11:46 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">your oil pressure is fine. when your up in the rpms a bit your oil pressure should be around 75.</TD></TR></TABLE>
yea under load u should be up there in psi
Old Aug 11, 2005 | 02:34 PM
DaveF's Avatar
Default Re: normal #'s? (chanluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chanluder &raquo;</TD></TR><TR><TD CLASS="quote">what kinda oil are you using guys? im using 5w-30</TD></TR></TABLE>
in the race car, we use royal purple racing 41.
in my street cars ive always used castrol gtx 10-40 or 10-30
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
dragvixen
Jul 10, 2009 11:20 AM
platinum00
May 14, 2006 06:40 AM
Audipwr1
Jul 18, 2003 02:37 PM
