EGT to high?!?!?!
Old Oct 9, 2002 | 12:56 PM
rexboy04's Avatar
Default EGT to high?!?!?!
I recently put a drag kit on my ls integra and i got a new fuel pump for it. The EGT was 8 at idol and the 12-13 driving. The fuel pump lowerd it to 6 idol and 11-12 driving. People tell me it is still to high... what should i do to lower it??
Old Oct 9, 2002 | 01:11 PM
falcongsr's Avatar
What is this crap?
Default Re: EGT to high?!?!?! (rexboy04)
greddy egt?
800c at idle is crazy.
Old Oct 9, 2002 | 01:19 PM
niedejb's Avatar
Default Re: EGT to high?!?!?! (falconGSR)
Hes talking F.
I idle around 8 and get 1300-1400 in boost.
Old Oct 9, 2002 | 01:23 PM
falcongsr's Avatar
What is this crap?
Default Re: EGT to high?!?!?! (niedejb)
phew. then he's ok...or even too rich?
Old Oct 9, 2002 | 01:42 PM
FredoSP's Avatar
is it a Greddy Gauge (EGT) or AutoMeter Pyrometer?
[Modified by FredoSP, 5:42 PM 10/9/2002]
Old Oct 9, 2002 | 03:22 PM
E Swift's Avatar
Default Re: EGT to high?!?!?! (FredoSP)
My EGT gauge reads about 800 when idle, and around 1200-1225 when boosting.
Old Oct 9, 2002 | 04:06 PM
Jared's Avatar
Default Re: EGT to high?!?!?! (E Swift)
I see 1300-1400F under heavy boost in the top of 3rd and 4th gear pulls.
Old Oct 9, 2002 | 04:21 PM
zojirushi's Avatar
Default Re: EGT to high?!?!?! (Jared)
what kinda egt readings are u guys getting going up hills??
Old Oct 23, 2002 | 06:03 PM
rexboy04's Avatar
Default Re: EGT to high?!?!?! (zojirushi)
its a greddy egt and at 7 lbs of boost its readin 12-13 on egt
Old Oct 23, 2002 | 07:35 PM
Blaze45's Avatar
Brrraaaap!
is the greddy egt in celcius or farenhight (i know i cant spell)
Blaze
Old Oct 23, 2002 | 07:48 PM
ion_four's Avatar
700-800ºF at idle (really depends on ambient temp)
1000ºF low speed cruising
1200-1300ºF going up a hill or high speed driving
I never really see over 1300-1400ºF boosting, even at high speeds, though I haven't taken it over about 90mph since I've had it turboed...drive responsibly
My car is running REALLY REALLY rich with stock timing at about 7psi of boost. I'm in the process of installing a MSD 6BTM (though it blew my ICM) and then I'll be able to lean it out a bit...
But, here's the thing...retarding timing INCREASES egt's and going closer to stoichiometric (14.7:1) A/F ratio from running rich would also increase egt's, so it's going to get hotter?! Maybe I need colder plugs? running one step colder than stock now (good luck finding colder for a d16z6)...
Old Oct 23, 2002 | 09:50 PM
hksturbolude's Avatar
Default Re: EGT to high?!?!?! (ion_four)
12-13 on a greddy EGT?! damn thats high...im at like 4 or 5 at idle, 7-8 in boost...and 850 max in boost or going up a hill...i think ur running too lean...and btw yeah the gredd gauge is in celsius...whoa thats really high thats in the red...
Old Oct 23, 2002 | 10:51 PM
B20C5 Turbo's Avatar
New User
The REAL question is where did you mount your probe?
Old Oct 23, 2002 | 10:57 PM
TurbothisLS's Avatar
Default Re: EGT to high?!?!?! (B20C5 Turbo)
i have the pyrometer...
mine is at like 8-9 idle
1200-1300 cruisin at 70 mph
1300-1400 under boost
Old Oct 23, 2002 | 11:36 PM
TriK's Avatar
Default Re: EGT to high?!?!?! (TurbothisLS)
where did you mount your probe?!?!?!?!
at 2 inch from the head i have
800 idle..
1375 cruizing at 70 mph
1600 VERY high speed pass..
over 1600 when thing are not working well
Old Oct 24, 2002 | 04:15 AM
DSF's Avatar
DSF
Default Re: EGT to high?!?!?! (TriK)
This shouldn't matter. Proper readings are with the probe intalled near the head. If he installed it father downstream, the reading would be getting cooler. The cause of high EGTs could be from a number of reasons...
* running lean (not leaner than 14:1 though because the temps should read cooler past stoich)
* running supa-dupa rich
* severly retarded timing
At any rate, I'd find out the cause asap
Old Oct 24, 2002 | 05:58 AM
autoEXturbo's Avatar
yea that's way high on the greddy egt. I think your running way to rich or your motor is gonna crap out soon. At idle i read 300 and at WOT i never get above 800. Correct me if i'm wrong, but i was told that the most you want it to get is 850.
Old Oct 24, 2002 | 07:53 AM
Default Re: EGT to high?!?!?! (autoEXturbo)
that's on the greddy egt right?
i am running the pyrometer so numbers are higher correct?
Old Oct 24, 2002 | 07:56 AM
yea, the numbers he's reading is on a greddy egt, which is way to high. I'm not sure how yours is. The greddy is in celcius i believe and 12-1300 degrees is way to hot.
Old Oct 24, 2002 | 08:47 AM
Muckman's Avatar
Moderator in Chief
Default Re: EGT to high?!?!?! (DSF)
I dont understand how if he was running lean his EGT would be too hot? I though it would be too hot if he was running rich? Please explain the relationship between lean/rich to EGT for me.
Old Oct 24, 2002 | 08:52 AM
tygsr's Avatar
Default Re: EGT to high?!?!?! (Muckman)
He is not running rich, he is running lean when he is that hot...the hotter the egt temps the leaner your a/f ratio..he should never go above 900c on the greddy..
Old Oct 24, 2002 | 08:54 AM
DSF's Avatar
DSF
Default Re: EGT to high?!?!?! (tygsr)
Read this tech article...
http://www.sdsefi.com/techegt.htm
It should clear up a lot of the misinformation floating around.
Old Oct 24, 2002 | 10:51 AM
Overblown-Teg's Avatar
I thought the greddy gauge only goes to about 1000 C
Old Oct 24, 2002 | 10:53 AM
DSF's Avatar
DSF
Default Re: EGT to high?!?!?! (Overblown-Teg)
[Modified by DSF, 2:53 PM 10/24/2002]
Old Oct 24, 2002 | 02:05 PM
rexboy04's Avatar
The Probe is on the 3rd cylinder of the manifold. my bad...its an autometer egt ^_^
[Modified by rexboy04, 11:10 PM 10/24/2002]
