NO POWER T3 setup 91 Si
Old Nov 28, 2007 | 04:58 PM
91siBoost's Avatar
Default NO POWER T3 setup 91 Si
i have a 91 Si stock D16A6 (rebuilt less than 15k miles ago), saab t3 (tb0357)internal wastegate 57 trim, 92 Talon side mount intercooler, SSQ Bov, HKS EVC, Apex'i S-AFC, boost meter, a/f meter,
pressure tested system from compressor inlet to throttle body holds 25psi no leaks w/car off. BOV holds fine. drive the car u can hear it spool up and the blow off valve release. but u cannot feel any power and boost guage doesn't go past 2psi. any help, suggestions please. can seem to figure this one out!!?
Old Nov 28, 2007 | 05:01 PM
Robert Padron's Avatar
Default Re: NO POWER T3 setup 91 Si (91siBoost)
Maybe your wastegate isn't fully shut and lets exhaust get out, causing it to only spool upto 2psi. That has to be it, check that.
Old Nov 28, 2007 | 05:02 PM
91siBoost's Avatar
why would it spool up? also when i do a manual psi test on it i can watch my waste gate open and close.
Old Nov 28, 2007 | 05:04 PM
91siBoost's Avatar
Default Re: NO POWER T3 setup 91 Si (Robert Padron)
i see maybe ur sayin it isnt closing all the way! i'll check that! i hope thats it man! i been working on this thing for like 6 months i wanna drive it now ya know!!
thanx-
Old Nov 28, 2007 | 08:32 PM
R1ce's Avatar
yea i was having the same problem, but bad wastegate so check that first.
and you said you can see your wastegate flap? when your exhaust is off right? lol just checking
Old Nov 29, 2007 | 11:42 AM
hellakapps's Avatar
did you get it figured out? i'd say wastegate also!!!!
Old Nov 29, 2007 | 01:25 PM
'94civic b16's Avatar
Default Re: NO POWER T3 setup 91 Si (hellakapps)
did you put the fire ring in when you installed the wastegate?
Old Nov 29, 2007 | 03:53 PM
sohczcturbo's Avatar
Default Re: NO POWER T3 setup 91 Si ('94civic b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’94civic b16 &raquo;</TD></TR><TR><TD CLASS="quote">did you put the fire ring in when you installed the wastegate?</TD></TR></TABLE>
saab t3 turbo buddy... incase you didn't know, internal waste gated. Hence all the talk about the "flap".
Nother for the waste gate flap out of adjustment
Old Nov 30, 2007 | 05:40 AM
91siBoost's Avatar
fire ring? wtf anyhoo the WG rod is adjustable so i tightened it all the way down an i GOT 4 Psi!!!! so i think the WG is bad or weak spring, gonna look into it some more today!! thanx every one for the help!?
Old Nov 30, 2007 | 06:12 AM
HiProfile's Avatar
I'm surprised nobody caught the fact you're running an electronic boost controller with an internal WG. You need a wastegate with ports on both sides of the diaphragm, and your Saab WG only has one.
Also if all you're using is the Apexi for tuning, I'd suggest you stop right now. W/o even using a wideband o2 sensor to check your air/fuel ratio, you could be going VERY lean, which is an easy way to toast a motor. 2-4 psi can be dealt with using the S-AFC, but beyond that and you have issues running WAY too much timing. If you aren't using good 93 octane gas and whatnot, your motor could be detonating right now, meaning its making LESS power with 4psi than it could be NA.
Old Nov 30, 2007 | 06:48 AM
splitime's Avatar
Default Re: NO POWER T3 setup 91 Si (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I'm surprised nobody caught the fact you're running an electronic boost controller with an internal WG. You need a wastegate with ports on both sides of the diaphragm, and your Saab WG only has one.
I'm unsure about the EVC... but the AVCR I had you can setup for internally wastegated setups. It just bleeds like a MBC instead of allowing boost into a 2nd port and equalizing/pressurizing.
Old Nov 30, 2007 | 07:19 AM
ryan89crx's Avatar
exhaust leak pre-turbo?
my guess would be WG issue though...
Old Dec 1, 2007 | 01:26 PM
91siBoost's Avatar
no exaust leaks, my evc does single port and dual port, any info on fuel management is much appreciated since my afc wont be enough? also Wide band coming soon! someone told me maybe the spring in my WG is too weak is this true. this is my first turbo kit and i made it (water leak tested everything i made).
please help !?
Old Dec 1, 2007 | 01:28 PM
91siBoost's Avatar
what do u recommend for an actuator?
Jeffrey9
Sep 19, 2008 06:23 AM
Duster
Jun 30, 2006 07:02 AM
hondaguyexsi
Aug 10, 2005 12:00 PM
vtec.dc2
Dec 16, 2002 01:43 PM
