Building own catchcan. is -8 AN Fitting big enough???
Old Dec 1, 2007 | 08:11 AM
melovesboost's Avatar
Default Building own catchcan. is -8 AN Fitting big enough???
im going to be building a similar catchcan setup to T1's.
Gonna run to the 2 on front of the valve cover and then have the 2 return hoses go to the back of the block.
Im using -*8AN fittings because i get them free at work.. and i have free hoses too so im just gonna fab up a steep box and make it work.
SO will the 8AN be big enough? should i add extra ports since they are a lil smaller?
Im Running a Benson GSR block 530 WHP. and my ****so can pukes here and there and messes up the engine bay that i like to keep clean.
Old Dec 1, 2007 | 12:37 PM
welfarepc's Avatar
the smaller the air channel the more oil the air will carry. that is bad.
the larger the air channel means the air flows better and oil doesnt go with it.
your setup might work but it should move a lot more oil than is necessary
Old Dec 1, 2007 | 01:48 PM
Jared's Avatar
depends all on how much blowby you plan to have
chillz03
Mar 13, 2009 04:08 PM
fireant
21
Nov 9, 2008 07:55 PM
Maco
May 10, 2003 08:49 AM
spettinger
13
Nov 16, 2002 12:51 AM
